Headlight
1.8K views 9 replies 5 participants last post by  Black1
Hi
I removed driver side head light to put bulb in now the head light doesn’t hold tight not sure what in doing wrong. Vw tourage 2008
To be clear, did you remove the headlight assembly to replace the bulb? If so you need to make sure it is in the whole way and flip the release lever back to hold it in.
Sent from my SM-G986U using Tapatalk
You are aware there is a locking lever on top of the assembly, correct?
Had that same problem not long ago. For lack of a better description their is Tongue & Grove arrangement on the bottom of the headlight, where the tongue on the bottom of the light need to slot into the grove in the body of the car. Took me plenty of practice goes before I got in in correctly. Then you need to secure the headlight with the locking lever as mentioned above.
