1 - 20 of 35 Posts
JustBrowsingLiNy
Discussion starter · #1 ·
This is going to be a bit silly since I do have the manual however it's not 100% clear what this bulb is called and can it be replaced?
It looks like it's an LED circuit board so I would imagine the answer is no It can't be replaced easily... Although the manual says this would be the left m1 or right M3 bulb which references page 136 to renew however 136 doesn't tell me anything about what I'm looking for... So I figured I'd post on here to see if anyone has changed this bulb?
I really would like to have the color match the other LEDs instead of dim yellowish color.
Discussion starter · #3 · (Edited)
Look on page 131 instead.... it's directing you to the incorrect page, but you already know which bulb you're trying to replace, so I'm not sure why you can scroll or search for that specific d
etail to find it.
Umm Thank you....?
Please let me know if this page helps you because it sure doesn't help me..
You seem confident in knowing what you are talking about so why the need to direct me to this page instead of actually helping?
Would it be because you don't know.... So please no need to reply if you don't know... It's okay to not know... I don't know that's why I am putting this on here... So if you can help please help, if you can't and just want to be a **** then please don't write back... There are better things you can do with your time..
Discussion starter · #8 ·
I can't believe I'm still trying to help all the users around here, that not only can't read, but can barely use simple logic to scroll or search in a manual for the correct snippet of information they are after.
It's because the document I'm referencing (quickly, just trying to figure out what your issue was) and the one you're showing are two different editions... so more than likely, different page numbers.
Here's my pg131 from my doc, edition 06.1017 which shows that "I know"..... maybe if you knew how to read your 2019 version, you could also go to the correct page number. :rolleyes:
It's too bad that service manuals don't have some sort of table of contents or something like that, which could help you skip to the correct section of a 400pg manual.
Send me your version of your manual since you're unable to read it, and I'll give you the page number from that version of it.... you know... since I don't know what I'm talking about and all.... :mad:
Where's your witty responses now?
Come on we need 30 replies to this thread on nonsense because you gotta be that guy...
Discussion starter · #15 ·
nope... don't care
I realize you've got a hardon for me, and it is what it is.... you're not the first or the last. (and no, I'm not interested)
That being said, I don't know why you're still barking about some apology that you feel you're entitled to.
Speaking of stupidity...
The bottom line is, you don't know how to read\navigate your own manual.... nothing more, nothing less!
Keep going though... this place has been pretty boring lately, so a little action could potentially spark up some traffic.
Discussion starter · #19 ·
Can I ask you a question?
What is the point of this message board then?
Clearly it's not for meeting people with personalities so if it's not for getting advice why does this exist?
You have 11, 898 posts so clearly you are an expert on why this message board is here?
Is it to tell me that I don't know how to read my manual?
What about you not being able to look at a picture and realize I don't have halogen headlights?
So what is this message board for?
You know I used to be maybe 20 years ago I used to be a member of a Lincoln forum that actually helped me change my engine install Headers among many other things... That's what a message board is for.. to help a 22-year-old drop his k member on his Lincoln Mark 8 and replace the engine along with many other helpful tips..
Wtf is the point of this message board other than a bunch of idiots that think they know it all
Discussion starter · #20 ·
And you reference my previous posts which is why I haven't really posted much at all since.
I don't think it's a coincidence the same idiot that wasn't helpful on that post, is the same idiot that gives me no help here other than aggravation.
Don't you have anything better to do with your time than not help anyone?
Which begs the question what is this message forum for if not for help?
Do you just enjoy having this be like Twitter? In other words garbage as opposed to being helpful?
1 - 20 of 35 Posts
