I have an RNS-510 (2010), upgraded to 1140/42. I have always had HD radio, but have been wanting to pick up the HD subchannels with this upgrade.
Question is 'how'?
I may be dense, but don't know how one accesses the HD channels.
thanks in advance!
According to sources on VW Navi the subchannels are not available on the RNS 510 unless you have a C unit. Most of the RNS 510's in the 09-10 Tregs were A and B units. It is a hardware change on the C unit that allows for subchannels, not software. So no worries on how to access them since you can't anyhow.
OK, if I can't have it then so be it - but if I had a 'C' unit, how would I get to the subchannels? I have no easy way of knowing what hardware I have, so I can only hope that since my car is a very late 2010 build date it isn't impossible that I would have a 'C' unit, but with my luck it will be the very last 'B'.
If we set aside using a VagCom or pulling the unit is there a quick way of telling that I am ignorant of?
VagCom should be under the tree this year!
Click "Station list" and it will show sub channel as a same station but with letters following the station frequency in a matter such as "HD1" "HD2" etc.....
Peter
Peter
Thank you!
