What changes from the tune? Boost, Fuel? I'm not looking for what you think changed. I want to know what exactly changed based on data, not seat of the pants evaluation.
Well you got 10 pages of discussion. That's pretty good. I'll collect that data for you. I have a CATA but I don't think there would be much difference.Not gonna happen... I tried long ago to get our users to play.... no bites
Looking for a Tuned\Deleted (CNRB) log if anyone wants...
If anyone has a Tuned and\or Deleted CNRB and VCDS, I'd be interested in seeing some values from a log. Let me know if you want to share, and I can help guide you on how to log what I'm after. These are the MVBs I'm looking for IDE00021 - Engine RPM IDE00190 - Charge air pressure: specified...www.clubtouareg.com
Group 1 - Field 0 | Group 1 - Field 1 | Group 1 - Field 2 | Group 1 - Field 3 | Group 10 - Field 0 | Group 10 - Field 2 | Group 15 - Field 1 | Group 20 - Field 3 | Group 21 - Field 3 | ||
Engine Speed - (G28) | Injection Quantity | High Fuel Pressure - (actual) | Coolant - Temperature (G62) | Mass Air Flow - (actual) | Boost Pressure - (actual) | Boost Pressure - (actual) | Engine Torque - (actual) | High Fuel Pressure - Control Valve | Quantity Measuring - Control Valve | |
/min | mg/str | bar | °C | mg/str | mbar | PSI | Nm | % | % | Air/Fuel Ratio |
I'm just used to PSI for boost so that's converted from bar.That's weird... I always thought sensors measured stuff
full emissions delete stock tune I am seeing EGT's of 856cI'd be curious to see both EGTs and Boost before and after. I could collect pre-tune CATA data that would align well with Lars's post tune as we have nearly the same vehicle. I've considered doing it but am worried it runs the EGTs too high.
remember you are reading absolute pressure not relative pressure, so it will be 15psi high.Hah, I read boost out over OBDII and it peaks at 50psi. I've long suspected the reading I'm seeing was off by some integer multiplier, sounds like probably 2x.
I didn't see any change in max boost or max fuel, but they could be changing the fuel delivery curve between min and max which I wouldn't have seen in my simplistic analysis.When I got my tune, Malone was basically in my backyard. I asked him various things about the tune. He said they don’t change boost, it’s mostly in the fuelling.
I'm trying to understand what Malone has changed in stage 1.You make power with fuel, timing and air in a diesel. The end. What exactly are we trying to accomplish with this thread?
especially with the CATA which has a smaller turbo than the gen 2 3.0 TDI.100 agree. Heck, most German cars are still coming under boosted from the factory but not the Touareg. They're off map and running warm even stock. There are European options for bigger turbos but not a ton of power to be made, easily, for the 3.0 TDI
Yes, I submitted a question.Have you tried, I dunno, asking them directly?
I'm still learning this.Toasty IAT.
I see you also chose to just go ahead with your own parameters instead of matching what I was attempting to collect, even after asking me.....
OK thanks for educating meThis shows if your tune is requesting more boost than an OEM setup, or if there's an issue where you're unable to make the requested boost (read charge leak) which could cause a rich condition and elevated EGTs.
Without this, we can't tell how much boost you're running if VCDS is reporting absolute pressure.
Unless you don't have any oxygen sensors, it should exist somewhere.
Knowing ambient temp allows for determining if your intercooling is up to task.... hot ambient temps naturally already result in hot IATs.... but if you have a massive delta, then you're either inducing way too much heat into the boost, or once again, something is wrong with your SMICs, etc.
I deleted everything but the DPF for a couple months while waiting for my exhaust. It seemed to work OK. The system still monitored DPF back pressure and did regens if needed.Nobody deleted everything but the DPF because...you can't. The DPF would clog of compaction in no time rendering the car inoperable.
You know that stock is one of the tune options, in addition to stage 1 and stage 2From this discussion, I would expect that the Malone tune would increase soot production, and require more frequent regens if done without a DPF delete.
I think anytime you add more fuel or boost, you are essentially making your engine bigger, but your emissions systems, like your DPF and SCR haven't gotten any bigger, so there could be issues depending on their capacity.I did not know that, I was only talking about tunes that increase power without increasing boost. I've gone back and forth about doing a tune, but if I did it would be just for horsepower, I wouldn't try to delete any emissions equipment.
I'm exactly in the same place. I'm happy with the existing power of the 3.0l CATA. I'm primarily trying to improve reliability. If I can reduce operating cost at the same time then that is a plus.Yeah, ultimately I do like going fast, but man is this stock Touareg already fast. I've been driving 70s-80s diesels most of my life, and this thing is mind blowingly fast, but crazy complex. I have zero interest in any changes that might make it less reliable in exchange for even more power, when ultimately towing and off-roading in remote places is my major use of this vehicle.
That's why I'm inclined to keep the stock tune with the DPFIt's all going to come down to the tune. It IS possible to have a killer tune that indeed lowers soot production or at least maintains OEM soot production; but lets face it, Malone or most other OTS tunes are not going to accomplish this. Especially not without logging.
Yes, I see they have a neet little program to graph the files. I have been on vacation so haven't had time to play with it.Bruh, use the tunezilla site to post easy to look at graphs instead of you fake CSV files... No one is going to spend all this time to download, convert, graph and then evaluate whatever you're posting to reply with anything useful.
You don't know a lot of things until you experience them. This is my first Diesel. If i didn't have a spare tire carrier it wouldn't be so bad. The carrier gets coated pretty badly. many people probably are not bothered.it still blows my mind that people don't realize this is going to happen
