I'm in the process of installing the THB System 8 hands free car kit for my Treo 600, also in a V10, so the query is timely.
I have a Kuda phone mount for it, but the kit is fairly wide (and deep) so it looks like it will project a bit closer to the driver than I had thought. Not sure yet if that will be a problem.
The mute wite should be no problem as it looks compatible with the NAV2 radio we both have.
The kit comes with a separate microphone which I plan to use and will probably place in one of the blanks in the overhead console.
The biggest problem with this kit is that it doesn't have an external speaker line, which is a big disappointment. I really want to use the factory setup, to be able to control volume from the steering wheel. I'm currently thinking about opening up the speaker module with the idea of trying to get access to low-level outputs to drive the radio.
I got the kit from ebay, and it works only with the GSM 600s, so no go if you are using Sprint.
Depending on how lazy I am, I may post pictures if I think it turns out. I bury my failures, though...
-Will
