1 - 14 of 14 Posts
If I am understanding this correctly... is this too much body roll? I have read of sway bar bushings that can go early. This could cause body roll due to play. Also you may not have TPS in your location, so I would also check tire pressure to see if that is within spec. No experience with air suspension, but this would be my last suspect.
I think you have something seriously wrong with your steering or suspension. Are you able to give us some more details on what you are experiencing? The fact that your steering is "heavy" is a big concern. This along with the new body roll problem seems to indicate that something has broken. As a safety concern, can you check or have somebody check to see if your car is safe to drive?
If language is a difficulty, try using Google Translate and then posting the result.
https://translate.google.com/?hl=en
Photos are also very useful. Please make sure it is safe to drive..
Stuart...
I think something is seriously wrong, we need more details please, if we are to be any help.
ردودكم هي قصيرة جدا وليس لديهم ما يكفي من التفاصيل لأحد أن تساعدك.
يرجى يمكنك البدء من جديد وبعناية وصف جميع الأعراض التي تعاني منها مع سيارتك مع أكبر قدر من المعلومات ممكن.
لقد استخدمت ترجمة جوجل لتحويل من الإنجليزية إلى العربية وهو ما أعتقد أنه لغتك الأم.
أعتذر إذا لم يكن.
أقترح أن تكتب مشكلتك في اللغة الخاصة بك واستخدام جوجل ترجمة لتحويل الرسالة إلى اللغة الإنكليزية.
https://translate.google.co.uk/?hl=en&tab=TT
Your replies are too short and do not have enough detail for anyone to help you.
Please can you start again and carefully describe all the symptoms you are experiencing with your car with as much information as possible.
I have used Google translate to convert from English to Arabic which I think is your native language.
I apologise if it is not.
I suggest you write your problem in your own language and use Google translate to convert your message into English.
You guys are super helpful.
Sounds like something may have failed catastrophically on his car.
Let's see if he can get an accurate problem statement for you to help him with. Bow Down Bow Down Bow Down Bow Down Bow Down Bow Down
1 - 14 of 14 Posts
