Confirmed, front diff.
Now ask for the parts needed and repair it.
Will put some photos once the parts arrive.
ok great!Confirmed, front diff.
HI RaulConfirmed, front diff.
Hi, my car has 195.000kms , fluid looks ok, no weird color or smell.HI Raul
What milage do you have on your car? I had similar noises in addition to a thumb. It all got sorted out by changing the differential fluid and transfer case fluid.
A fluid change may be a low cost solution if it's a high milage car and the front differential fluid has never been changed.
Micheld7.. that sounds like what mine is doing.. 2006 with 114,000 V6 gas... Can we rebuild that front Differential , do you know ?Long shot, but the bearing in your front differentials? Needle Bearing
Listen to this many times and very closely. Does it sound like in the video, a hollow, grinding type noise
Raul.. What did you find putting the car on the lift and spinning Wheels.. any luck?Tomorrow morning will put it secure in the air, disable Abs and TC by taking the fuse( otherwise TC is always kicking in and we cannot get wheels spinning )and we will try to be sure where the noise comes from.
I will keep you guys posted.
Fingers crossed it is from the center bearing...
I did, replied back on the post, took the abs and esp fuse and was able to put it moving in the air. The noise comes from the front diff.Raul.. What did you find putting the car on the lift and spinning Wheels.. any luck?
Yes, it is the front diff, it is not as bad as your's, i am going to change all bearings and oil.Micheld7.. that sounds like what mine is doing.. 2006 with 114,000 V6 gas... Can we rebuild that front Differential , do you know ?
Here we go.... View attachment 242961
Raul... are you doing this yourself.. or having a shop do it ? Seems like $1250 is a very reasonable price.. IF it solves the grinding noise issues.. Please keep us posted..Thanks..Here we go.... View attachment 242961
I am having a shop doing it, $1250? I hope not more than 300€ with the bearings included 😂😂😂.Raul... are you doing this yourself.. or having a shop do it ? Seems like $1250 is a very reasonable price.. IF it solves the grinding noise issues.. Please keep us posted..Thanks..
