1 - 20 of 31 Posts
I have a grinding noise on my T1 V6 Touareg.
I can't find the cause, we already tried to put the car in the air and engage drive ,but the TC kicks in and we cannot discover the problem.
It is like wear breaking pads against the rotors .
We have changed already brake pads, wheel bearings.
The grinding keeps even if we put it in Neutral.
All oil levels are ok, no metal on the oil etc.
It sounds like a dry bearing and it is getting worst.
2011 VR6 FSI LUX
A member on here recently had a weird noise like that. They said they found that one of the springs on the emergency brakes had broken and was scraping. They had to put it on a lift and remove the wheels to se it I believe.
Thread >>> Squealing noise from rear driver’s side wheel
If in neutral then presumably the drivetrain isnt engaged so not moving so the grinding must be engine related. Please clarify?
Long shot but try putting the car in reverse on a safe and empty piece of road. Reverse backwards at speed then brake very hard.
If you have a trapped stone in one of the brakes that might clear it.
Pads and rotors have been changed and the noise persists.
In neutral but moving.
It increases with speed.
On a downhill for example.
You said the car was in the air!! Put it back in the air & rotate each wheel in turn. Also check the prop shafts which is easy on a lift & front rear diffs & transfer box. Try & isolate it difficult while driving but not so on a lift.
2005 Touareg V8
Long shot, but the bearing in your front differentials? Needle Bearing
Listen to this many times and very closely. Does it sound like in the video, a hollow, grinding type noise
I went through the same thing. Thought it was pads or something with the brakes, replaced everything to no avail. Replaced the center carrier assembly, nope. Then thought it might be wheel bearings but no. Indeed it was the front differential.
The way I finally diagnosed was using a set of "Chasis Ears" placed at points on the front axle / transaxle. It quicly became apparent that it was the transaxle bearings. (the long side, left side I seem to recall). If you drain the front diff fluid and see shiny particles in there, that is another clear indicator.
I replaced the front transaxle with a used unit from an Audi Q7 and all good. It was a big job but I was able to do it on my own as I have a lift at home.
Discussion Starter #12
It is close to this, yes. But not so loud. And it does not do the bumping noise.
Discussion Starter #13
Are all front diff alike?
Mine is a 3.2L , is it interchangeable with all the TDI's?
Are the ones on the Cayenne V6 alike?
No, they are all not the same. Different ratios. Some compatible, some not. There is compatibility across brands but you must ensure ratios are the same as yours.
Discussion Starter #18
Let us know whenever you get done with it
Tomorrow morning will put it secure in the air, disable Abs and TC by taking the fuse( otherwise TC is always kicking in and we cannot get wheels spinning )and we will try to be sure where the noise comes from.
I will keep you guys posted.
Fingers crossed it is from the center bearing...
Discussion Starter #19
Are those bearings the referenced on this topic ? Or another bearings?
If i will have to open the diff better to change everything.
1 - 20 of 31 Posts
