Hello Club,
So I bought and installed VAG-COM as everybody recommended. But now I need some help and guidance with the output. My Touareg is a 2006, so I expected some glitches. I would greatly appreciate some expertise and/or best guesses about the following reports. I'm posting each error as a separate reply for clarity. Here's the first set....
Address 01: Engine Labels: 022-906-032-BMX.lbl
Part No SW: 022 906 032 GT HW:
Component: MOTRONIC ME7.1.1G 7532
Revision: 00000000 Serial number: VWZ3Z0E2387112
Coding: 0000133
Shop #: WSC 31414 000 00000
VCID: 63C54907A1A06306E91-5000
10 Faults Found:
001393 - Brake Switch (F)
P0571 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 1302 /min
Load: 40.8 %
Speed: 9.0 km/h
Temperature: 64.0°C
Temperature: 39.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 0.000 V
000104 - MAP/MAF <-> Throttle Position Correlation
P0068 - 002 - - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 272759 km
Time Indication: 0
Freeze Frame:
RPM: 1430 /min
Load: 47.4 %
Speed: 61.0 km/h
Temperature: 86.0°C
Temperature: 39.0°C
Voltage: 0.000 V
000257 - Mass Air Flow Sensor (G70)
P0101 - 004 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 21
Reset counter: 255
Mileage: 272759 km
Time Indication: 0
Freeze Frame:
RPM: 1430 /min
Load: 47.8 %
Speed: 61.0 km/h
Temperature: 86.0°C
Temperature: 39.0°C
Voltage: 0.000 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 9
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 711 /min
Load: 19.6 %
Speed: 0.0 km/h
Temperature: 78.0°C
Temperature: 42.0°C
Voltage: 0.000 V
000770 - Cylinder 2
P0302 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 711 /min
Load: 19.6 %
Speed: 0.0 km/h
Temperature: 78.0°C
Temperature: 42.0°C
Voltage: 0.000 V
000771 - Cylinder 3
P0303 - 001 - Misfire Detected - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 272774 km
Time Indication: 0
Freeze Frame:
RPM: 699 /min
Load: 14.9 %
Speed: 0.0 km/h
Temperature: 83.0°C
Temperature: 50.0°C
Voltage: 0.000 V
000774 - Cylinder 6
P0306 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 272774 km
Time Indication: 0
Freeze Frame:
RPM: 699 /min
Load: 14.9 %
Speed: 0.0 km/h
Temperature: 83.0°C
Temperature: 50.0°C
Voltage: 0.000 V
000772 - Cylinder 4
P0304 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 272774 km
Time Indication: 0
Freeze Frame:
RPM: 699 /min
Load: 14.9 %
Speed: 0.0 km/h
Temperature: 83.0°C
Temperature: 50.0°C
Voltage: 0.000 V
000769 - Cylinder 1
P0301 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 272774 km
Time Indication: 0
Freeze Frame:
RPM: 1283 /min
Load: 30.2 %
Speed: 11.0 km/h
Temperature: 87.0°C
Temperature: 43.0°C
Voltage: 0.000 V
000773 - Cylinder 5
P0305 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 272774 km
Time Indication: 0
Freeze Frame:
RPM: 696 /min
Load: 15.3 %
Speed: 0.0 km/h
Temperature: 83.0°C
Temperature: 53.0°C
Voltage: 0.000 V
Coding: 0000133
10 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 1302 /min
Load: 40.8 %
Speed: 9.0 km/h
Temperature: 64.0°C
Temperature: 39.0°C
Voltage: 0.000 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 272759 km
Time Indication: 0
Freeze Frame:
RPM: 1430 /min
Load: 47.4 %
Speed: 61.0 km/h
Temperature: 86.0°C
Temperature: 39.0°C
Voltage: 0.000 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 21
Reset counter: 255
Mileage: 272759 km
Time Indication: 0
Freeze Frame:
RPM: 1430 /min
Load: 47.8 %
Speed: 61.0 km/h
Temperature: 86.0°C
Temperature: 39.0°C
Voltage: 0.000 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 9
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 711 /min
Load: 19.6 %
Speed: 0.0 km/h
Temperature: 78.0°C
Temperature: 42.0°C
Voltage: 0.000 V
000770 - Cylinder 2
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 711 /min
Load: 19.6 %
Speed: 0.0 km/h
Temperature: 78.0°C
Temperature: 42.0°C
Voltage: 0.000 V
000771 - Cylinder 3
Freeze Frame:
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 272774 km
Time Indication: 0
Freeze Frame:
RPM: 699 /min
Load: 14.9 %
Speed: 0.0 km/h
Temperature: 83.0°C
Temperature: 50.0°C
Voltage: 0.000 V
000774 - Cylinder 6
Freeze Frame:
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 272774 km
Time Indication: 0
Freeze Frame:
RPM: 699 /min
Load: 14.9 %
Speed: 0.0 km/h
Temperature: 83.0°C
Temperature: 50.0°C
Voltage: 0.000 V
000772 - Cylinder 4
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 272774 km
Time Indication: 0
Freeze Frame:
RPM: 699 /min
Load: 14.9 %
Speed: 0.0 km/h
Temperature: 83.0°C
Temperature: 50.0°C
Voltage: 0.000 V
000769 - Cylinder 1
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 272774 km
Time Indication: 0
Freeze Frame:
RPM: 1283 /min
Load: 30.2 %
Speed: 11.0 km/h
Temperature: 87.0°C
Temperature: 43.0°C
Voltage: 0.000 V
000773 - Cylinder 5
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 272774 km
Time Indication: 0
Freeze Frame:
RPM: 696 /min
Load: 15.3 %
Speed: 0.0 km/h
Temperature: 83.0°C
Temperature: 53.0°C
Voltage: 0.000 V
