As the title says, I'm going to attempt to drop the trans on my new-to-me 06 V8 (yes, I know you're supposed to pull with the engine, but I do not have a full lift and am doing it in my garage) to replace what appears to likely be a bad input shaft seal, or at least something in the area. There is trans fluid coming out of the little drain hole between the engine and transmission. I found this link https://www.transmissiondigest.com/front-seal-blowout-after-converter-replacement-in-09d-t-transmissions/ so I may check for that. Unfortunately I do not have much info on service history.
My question is, what else should I check for while I'm doing this job? I have a few odds and ends to take care of (small coolant leak in the area). There is an exhaust leak that sounds like it's from the driver-side manifold as well.
While I'm at it, any idea where the wiring harness for the rear diff lock and left rear damper come into the cabin? Both are throwing codes in VCDS, and I just cleared 33 codes by fixing some of the splices in the driver footwell, so I would not be surprised if there were more wiring problems elsewhere (I may have even missed some-a few wires were so corroded that I broke them by hand).
I attached a full auto-scan
Thanks!
Thanks!
Code:
VCDS
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 22.3.1(x64) Data version: 20220407 DS337.0
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Thursday,05,May,2022,12:39:15:44415
VIN: WVGMM77L26D010136 License Plate:
Mileage: 161880km-100587mi Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGMM77L26D010136 Mileage: 161880km-100587miles
Address 01: Engine
Labels: 077-907-560-AXQ.lbl
Part No SW: 4D0 907 560 DF HW: 8E0 907 560
Component: 4.2L V8/5V
G 0020
Revision: 00000000 Serial number: VWZ3Z0E6365462
Coding: 0007875
Shop #: WSC 31414 000 00000
VCID: 6D87C7FA818B2993149-513C
VINID: 9E65DD7471DC0865000400431864D7C8D4
No fault code found.
Readiness: 0010 0101
Address 02: Auto Trans
Labels: 09D-927-750.clb
Part No: 09D 927 750 DB
Component: AL 750 6A
0742
Coding: 0004216
VCID: 71BFDB8A9DB3CD73301-5160
Address 03: ABS Brakes
Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 G
Component: ESP ALLRAD MK25 0203
Coding: 0014594
VCID: 3D2737BA916B7913E49-5160
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
-------------------------------------------------------------------------------VCDS
Self-Diagnosis Log
Page 2
Address 05: Acc/Start Auth.
Labels: None
Part No SW: 7L0 909 137 HW: 5WK 484 92
Component: 0E Kessy
6700
Revision: 67005514 Serial number: VWZ3Z0E6365462
Coding: 0131304
VCID: 70B9DE8E96B9C47B3FF-5160
Component: ELV
XXXX
4 Faults Found:
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
011 - Open Circuit
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
011 - Open Circuit
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
001 - Upper Limit Exceeded
00183 - Interior Access/Start Authorization Antenna 1 (R138)
011 - Open Circuit
Address 06: Seat Mem. Pass
Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0701
Shop #: WSC 00000 000 00000
VCID: 77ABE592F3D79343FE5-5160
Address 08: Auto HVAC
Labels: None
Part No: 7L6 907 044 L
Component: CLIMAtronic 2+2 4018
Coding: 0020030
Subsystem 1 - Part No: 7L6 907 049 D
Component: CLIMAtronic FOND 0400
Self-Diagnosis Log
Page 3
Address 09: Cent. Elect.
Labels:. 7Lx-937-049-V1.clb
Part No: 7L6 937 049 M
Component:
3001
Coding: 0105692
VCID: 46D55856C4BD3ACBB53-5160
Address 15: Airbags
Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 H
Component: 01 Airbag 8.4E++H01 0562
Revision: BB38727 Serial number: 0003704:
Coding: 0012337
VCID: 2809F6EE6EE9CCBBA7F-5160
Subsystem 1 - Part No: 7L0 959 339 C
Component: BF-Gewichtsens. 006 0008
Address 16: Steering wheel
Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 E
Component: Lenksäulenmodul 3301
Coding: 0000232
VCID: 41DF4B4AED931DF3801-5160
Address 17: Instruments
Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 981
Component: KOMBIINSTRUMENT RB8 3135
Coding: 0005231
Shop #: WSC 02132 444 84388
VCID: 76B5E896F4DDEA4BE53-5160
Self-Diagnosis Log
Page 4
Address 19: CAN Gateway
Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<>CAN
0101
Coding: 0000006
Shop #: WSC 09407 002 104857
Address 1C: Position Sensing
Labels: 7L6-919-879.lbl
Part No: 7L6 919 879 A
Component: JCI PathPoint
2200
VCID: 45D75F5AF9BB31D3BC9-5160
Address 22: AWD
Labels: None
Part No: 0AD 927 755 AJ
Component: TRANSFERCASE
0100
VCID: 03538142B70FCFE3D2D-5160
Address 29: Left Light
Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) 0001
Coding: 0000017
VCID: 6695B8D6A47D1ACB553-5160
2 Faults Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
01539 - Headlights Not Adjusted
Self-Diagnosis Log
Page 5
Address 32: Differential Locks
Labels: None
Part No: 0AC 927 771 C
Component: SG-Quersperre
5020
VCID: 382926AEBE495C3B37F-5160
1 Fault Found:
02035 - Hall Sensor 1
010 - Open or Short to Plus
Address 34: Level Control
Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 F
Component: LUFTFDR.-CDC- 3C3P1 3081
Coding: 0015521
VCID: 36352896B45DAA4B253-5160
2 Faults Found:
00144 - Rear Left Dampening Adjustment Valve (N338)
012 - Electrical Fault in Circuit
Address 36: Seat Mem. Drvr
Labels: None
Address 37: Navigation
Labels: 7L6-919-887-DVD.lbl
Part No: 7L6 919 887 M
Component:
Navigation 0044
Coding: 0000101
VCID: 50F97E0E36F9E47B1FF-5160
1 Fault Found:
014 - Defective
Self-Diagnosis Log
Page 6
Address 39: Right Light
Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
Coding: 0000003
VCID: 678BB5D2A37703C36E5-5160
Address 46: Central Conv.
Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 F
Component: 33 HSG
0300
Coding: 0000085
VCID: 3FDB4DB29B676B03F65-4B1E
Subsystem 1 - Part No: 7L0 959 701 H
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 H
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 D
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 D
Component: Tuersteuergeraet HR 0201
4 Faults Found:
00927 - Terminal 30 (Right)
011 - Open Circuit - Intermittent
01516 - Terminal 30; Left
00926 - Terminal 30
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded
Address 47: Sound System
Labels:
VCID: 55F78F1A0C0B8153CC9-5160
Note: Excessive Comm Errors
Address 56: Radio
Labels:
VCID: 55F78F1A0C0B8153CC9-FFFE
Self-Diagnosis Log
Page 7
Address 68: Wiper Electr.
Labels: 7L0-955-119-V2.clb
Part No: 7L0 955 119 K
Component: Front Wiper
4027
Coding: 0000855
Shop #: WSC 31414 000 376832
VCID: 3C213ABE8A71701BD37-5160
Subsystem 2 - Part No: 1K0 955 559 R Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 010 1010
Coding: 00208933
Shop #: WSC 31414
Address 6C: Back-up Cam.
Labels: 5N0-907-441.clb
Part No SW: 7L6 907 441 HW: 7L6 907 441
Component: J772__Rearview
0051
Revision: 00H07000 Serial number: PA8 J540444
Coding: 0000101
VCID: 72BDD48698B5F66BC9B-5160
Address 6E: Ctrl Head Roof
Labels: None
Part No: 7L6 919 044 N
Component: DACHDISPLAY
0539
Revision: 00800539 Serial number: 2009289.07
VCID: 42DD4446E89506EB99B-5160
Address 76: Park Assist
Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0E Einparkhilfe 1107
VCID: 392F23AA85434533C81-5160
End----------(Elapsed Time: 08:36, VBatt start/end: 14.0V/14.0V)-----------
