1 - 8 of 8 Posts
Morning all,
Does a DIY for glowplugs / harnesses exist for the V6 TDI ? Tried doing a search with no luck.
Thanks in advance!
2015 R Line V8
and....BUMP.
Currently searching for the same info. Noob y/Hedditch/Anyone? Thoughts/links etc please. Need to replace #2 Glowplug...so figured "one out all out"
Any idea on parts costs? Where from etc?
Can't help on this - glow plugs are what I have on the landing so I can see my way to the loo at night!
I haven't done the ones on my Treg, but on my other diesels (including a Golf TDI), you just pull the boot off and remove the plug with a deep socket. Kind of like changing a spark plug. The system will show a fault if the harness is damaged. Obviously, if you need a new harness, get it from the dealer. Plugs? Not sure if there are aftermarket plugs available. I bought plugs off eBay for the Golf (brand name).
I think it's a bigger job on the Treg - looks like the intake has got to come off.
Swivel, extension, deep socket and a piece of hose is all you need. The intake does not need to be removed. At least not according to a couple of Youtube videos I just watched.
Discussion Starter · #7 ·
The videos show Audi A6's. Mine is very similar, and I can see and access all 6 glow plugs.
Sent from my LG-D852 using Tapatalk
1 - 8 of 8 Posts
