1 - 11 of 11 Posts
Braedon T1
07 V10 TDI T1 / 08 RS4 / 04 A4 Ultrasport / Wifeys 16 S3
Discussion starter · #1 ·
Can't seem to figure out the issue here I have scanned with vcds and tried replacing the boost sensor map sensor No luck
Codes are as follows.
Truck is tuned Malone, no flaps
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGPT77L87D011244 Mileage: 233470km-145071miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 070 906 016 CQ HW: 028 101 196 2
Component: V10 5,0L EDCG001AGMÂŞ9805
Revision: --H02--- Serial number: VWZ3Z0F6504488
Coding: 0060575
Shop #: WSC 66565 257 00032
VCID: 619FA5B04D55BBD2605-5184
VINID: 9E65E09071DC207500041084104BADAB42
2 Faults Found:
000567 - Manifold Pressure / Boost Sensor (G31)
P0237 - 000 - Signal too Low - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 233470 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.32 V
Bin. Bits: 00001000
Absolute Pres.: 173.4 mbar
Absolute Pres.: 2182.8 mbar
001648 - Glow Plug Module 1; Glow Plug Circuit
P0670 - 000 - Electrical Malfunction
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 233470 km
Time Indication: 0
Freeze Frame:
RPM: 630 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 00001000
Temperature: 11.7°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No SW: 09D 927 750 DP HW: 09D 927 750 DP
Component: AL 750 6A 0856
Revision: 00H51000 Serial number:
Coding: 0004216
Shop #: WSC 31414 000 00000
VCID: 7F5B03C8DBE16D22761-5160
No fault code found.
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 G
Component: ESP ALLRAD MK25 0203
Coding: 0022786
VCID: 3D2739C0916DBF3224D-5184
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
012 - Electrical Fault in Circuit
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 137 A HW: 5WK 485 02
Component: 29 Kessy 6700
Revision: 67006015 Serial number: VWZ3Z0F6504488
Coding: 0147688
VCID: 313F15F05D354B52B05-5184
Component: ELV XXXX
4 Faults Found:
00956 - Key 2
002 - Lower Limit Exceeded
00668 - Supply Voltage Terminal 30
009 - Open or Short to Ground - Intermittent
00087 - Terminal 30 for Starting Relevant Consumers
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
001 - Upper Limit Exceeded
Address 06: Seat Mem. Pass Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0701
Shop #: WSC 00000 000 00000
VCID: 77ABEBE8F3D155623E1-5184
Address 08: Auto HVAC Labels: 7L6-907-044.clb
Part No: 7L6 907 044 AB
Component: CLIMAtronic 2+2 4325
Coding: 0020030
Shop #: WSC 25807 128 68113
VCID: 74B1DCE4E2A73E7A1B3-5184
Subsystem 1 - Part No: 7L6 907 049 E
Component: CLIMAtronic FOND 0400
5 Faults Found:
00711 - Left Footwell Flap Positioning Motor (V108)
000 - -
01810 - Actuating Motor for Temperature Flap; Right (V159)
000 - -
00712 - Right Footwell Flap Positioning Motor (V109)
000 - - - Intermittent
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded - Intermittent
02599 - Rear Left Temperature Flap Motor (V313)
000 - -
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L6 937 049 N
Component: 3002
Coding: 0110815
Shop #: WSC 09146 444 84835
VCID: 47CB5B28C3B1E5E28E1-5184
8 Faults Found:
01494 - Bulb for Parking Lamps; Left (M1)
010 - Open or Short to Plus
00978 - Lamp for Low Beam; Left (M29)
00968 - Right Turn Signals
014 - Defective - Intermittent
01498 - Bulb for Parking Lamps; Right (M3)
00979 - Lamp for Low Beam; Right (M31)
01499 - Bulb for High-Beams; Right (M32)
010 - Open or Short to Plus - Intermittent
00070 - Starting Battery Voltage
008 - Implausible Signal
00907 - Intervention load Management
000 - -
Address 11: Engine II Labels: Redir Fail!
Component: V10 5,0L EDCG001AGSÂŞ9805
Coding: 0060575
3 Faults Found:
006484 - Glow Plug Control Module 2 (J703)
P1954 - 000 - Malfunction in Glow Plug Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 233470 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.25 V
Bin. Bits: 00001011
Temperature: 12.6°C
Bin. Bits: 00110000
001654 - Cylinder 6 Glow Plug Circuit (Q15)
P0676 - 000 - Electrical Fault
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 233470 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.25 V
Bin. Bits: 00001011
Temperature: 12.6°C
Bin. Bits: 00110000
001656 - Cylinder 8 Glow Plug Circuit (Q17)
P0678 - 000 - Electrical Fault
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 233470 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.25 V
Bin. Bits: 00001011
Temperature: 12.6°C
Bin. Bits: 00110000
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 H
Component: 05 Airbag 8.4E++H01 0562
Revision: BB38727 Serial number: 0008639:
Coding: 0012341
VCID: 2809F8946EEF0A9A67B-5184
Subsystem 1 - Part No: 7L0 959 339 C
Component: BF-Gewichtsens. 006 0008
Part No: 7L6 953 549 H
Component: Lenksäulenmodul 3401
Coding: 0010032
VCID: 44D14C24F287CEFA6B3-5184
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 981 R
Component: KOMBIINSTRUMENT RB8 3211
Coding: 0007231
VCID: 48C95814CEAFEA9A87B-5184
Address 18: Aux. Heat Labels: 7L6-819-008.clb
Part No: 7L6 815 071 D
Component: Standheizung E1MAC
Coding: 0000100
VCID: 33331FF8A7297942C29-5184
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B9D0F496BF025AFFB-5184
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879 A
Component: JCI PathPoint 2200
VCID: 45D75120F9BDF7F27CD-5184
Address 22: AWD Labels: None
Part No: 0AD 927 755 AT
Component: TRANSFERCASE 0114
VCID: 0D47A900E14D4FB274D-5184
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 H
Component: LUFTFDR.-CDC- 3C3P1 3099
Coding: 0015521
VCID: 382928D4BE4F9A1AF7B-5184
2 Faults Found:
01400 - Suspension Level Control
001 - Upper Limit Exceeded - Intermittent
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzverstellung 0703
Address 37: Navigation Labels: 7L6-919-887-DVD.lbl
Part No: 7L6 919 887 M
Component: Navigation 0047
Coding: 0000101
VCID: 50F9707436FF225ADFB-5184
Address 46: Central Conv. Labels: 7L0-959-933.clb
Part No: 7L0 959 933 H
Component: YM HSG 0400
Coding: 0000085
VCID: 41DF4530ED95DBD2405-4B1E
Subsystem 1 - Part No: 7L0 959 701 H
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 H
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 D
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 D
Component: Tuersteuergeraet HR 0201
2 Faults Found:
01134 - Alarm Horn (H12)
000 - -
00488 - Rear Right Outside Door Handle Central Locking Button (E372)
007 - Short to Ground
Address 47: Sound System Labels:
VCID: 55F781600C0D47720CD-5184
Note: Excessive Comm Errors
Address 55: Headlight Range Labels: 7L6-907-357.lbl
Part No SW: 7L6 907 357 HW: 7L6 907 357
Component: AFS-Steuergeraet 0003
Revision: H09 Serial number:
Coding: 0000009
VCID: 78A9E8D4FECF5A1A37B-5184
Subsystem 1 - Part No: ID-L fehlt Labels: ID-55-01.CLB
Component: AFS-Lst.-Modul l ....
Coding: 00000255
Subsystem 2 - Part No: ID-R fehlt Labels: ID-55-02.CLB
Component: AFS-Lst.-Modul r ....
Coding: 00000255
7 Faults Found:
01042 - Control Module; Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 238
Time Indication: 0
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 238
Time Indication: 0
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 238
Time Indication: 0
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 238
Time Indication: 0
02233 - Left Headlight Power Output Stage (J667)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 238
Time Indication: 0
02234 - Right Headlight Power Output Stage (J668)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 238
Time Indication: 0
01328 - Convenience System Data Bus
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 238
Time Indication: 0
Address 56: Radio Labels: 7L6-035-186-DVD.lbl
Part No: 7L6 035 186 E
Component: Radio 0047
Coding: 0014062
VCID: 353721E0A95D6772ECD-5184
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L0 955 119 K
Component: Front Wiper 4027
Coding: 0000341
Shop #: WSC 31414 000 376832
VCID: 3C2134C48A77B63A133-5184
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 250707 046 0204
Coding: 00208933
Shop #: WSC 31414
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 G HW: 7L0 907 383 G
Component: ANHAENGERELEKTRONIK 8854
Coding: 0000002
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7L6 907 441 HW: 7L6 907 441
Component: J772__Rearview 0051
Revision: 00H07000 Serial number: PA8 J650151
Coding: 0000101
VCID: 72BDDAFC98B3304A09F-5184
Address 6D: Trunk Elect. Labels: 7L6-959-107.clb
Part No SW: 7L6 959 107 HW: 7L6 959 107
Component: J605 HECKKLAPPE 1110
Revision: --H05--- Serial number: --------004133
Coding: 0022110
2 Faults Found:
03234 - Functionality Limited due to Critical Electrical Condition
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 246
Time Indication: 0
03074 - Rear Lid Inclination Sensor (G549)
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 17
Reset counter: 243
Time Indication: 0
Address 6E: Ctrl Head Roof Labels: None
Part No: 7L6 919 044 T
Component: DACHDISPLAY 0539
Revision: 00900539 Serial number: 2009289.07
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0E Einparkhilfe 1107
VCID: 392F2DD085458312085-5184
End----------(Elapsed Time: 08:12, VBatt start/end: 14.0V/13.8V)-----------
Discussion starter · #6 ·
Yea. The batteries were brand new but then after a road trip I had to pull the motor and do all the work. So now that I have hooked them up to a charger they are doing better. But I still can't seem to figure the boost code and the glowplugs. Has to be something electrical.
I changed the boost sensor still codes. Might have to take it to the shop I'm not too good with electrical issues.
9 volts? That battery is literally dead
Discussion starter · #8 ·
After charging both batteries and letting it idle from time to time. They both hold charges. But they are still holding the codes for glow plugs.
Sounds about right. Glad you got it fixed.
1 - 11 of 11 Posts
