1 - 8 of 8 Posts
Brake light warning could very likely be the third brake light going out. It is LEDs and is intermitent when they are getting ready to go out. It took mine almost a full year before it finally died. I replaced mine myself and it is not a hard job to do at all. The headlight issue sounds like a loose assembly in the bucket. You can fix that yourself as well but tightening the lock mechanism to make it more secure. In saying that though you need to be very careful when working on that because everything is fragile. Including the tool to lock the assembly back down.
Sounds like mine. Same deal....start or stop would throw an error. Very infrequently though. Since then I've removed and re-seated both headlamp modules and all is OK lately. Before the end of the summer I'll want to take Geoff up on his offering for the xenons he has for sale.
Discussion starter · #7 ·
i checked the rear lights and i figured out which one was going out. its the driver brake light. as far as the front lamps go, i have the xenon so how do i go about adjusting them so the warning light wont come back on?
I have the same check lights warning coming on. I discovered I had those cool little fog lights. It only came on when I activated the second function (rear fogs). But now the warning stays on. Can anyone help? I did notice that the rear lights have condensation on the inside of the covers. But the manual said that sometimes this may be normal but will go away when I turn the lights on. I have tried turning the rear fogs on and nothing seems to alight. I am thinking that now I have fused rear fog lights and thats the reason for the warning light. Does this sound feasible?
1 - 8 of 8 Posts
