Hello folks. I'm new to the forum as well as having a touareg. I recently purchased a 2006 v8. Just got the obdeleven doodad as opposed to the vagcom to save a bit of money. I have just a few problems with my new vehicle so I thought codes would be a good place to start.
1. Tends to wind up a bit far off the line. Almost 3k rpm at times. Have done the throttle adaptation relearn to no avail.
2. Kessy doesn't seem to work at all.
3. Dealer unable to program more than one key at a time.
4. Steering wheel doesn't come forward when I start car. Will go back to exit postion when turned off.
5. Mystery 3 position switch in armrest. Doesn't look factory. Though does look installed well.
6. Steering doesn't seem to return very fast or well after turning. Maybe expecting to much?
7. Rear cam there. Doesn't work.
8. Battery died. Replaced. (Not as hard as I heard) possible bad alternator cable? Dash gauge reads 13-14v @ idle.
I hope you fellas can help out. I'd be glad to help out here at this forum. I have a feeling I'll be here a lot for a while.
Thanks!
Thanks!
