I am driving a 2005 model V10 TDI Touareg. What a nice vehicle!!! We have done 370 000km and I am not even halfway. Recently she started to “shudder” under hard acceleration. My first gut feel was that the gearbox is struggling to handle the torque and started to “slip”. As I mentioned, this only happen under hard acceleration. I have changed the transmission oil and during the same process also removed and cleaned the valve body. This certainly smoothed out the changes a bit but did not do anything for the shudder under high torque.
Can anybody help me??
propshaft bearing carrier. Also known as carden shaft bearing carrier.
Google will reveal hordes of info.
x2.
Very well known fault usually occurring after 60,000 miles or 5 years, whichever comes first. Some go sooner, some go later, some don't go at all.
If it lets go, the vibration makes the car undriveable.
Can you feel any knocking/vibration if you place you hand flat on top of the centre console between the seats?
There are lots of threads on here - here's a couple.
http://www.clubtouareg.com/forums/f43/center-propshaft-carrier-bearing-21876-3.html
http://www.clubtouareg.com/forums/f43/prop-shaft-centre-bearing-24651-4.html
Can be fixed for nothing, or $2,000 and prices in between.
It's easy to inspect the centre bearing but best done on a lift with a strong light.
You will see there is a outer ring of thick rubber and an inner ring of thick rubber and they are joined by a much thinner diaphragm.
This is what cracks or splits.
