1 - 2 of 2 Posts
Hi Everybody,
I'm working on my son's 2007 3.6L which is experiencing low power at acceleration, stuttering, high revs without shifting. According to him, it came on suddenly over the last week. He parks the car outside at his college in a large parking lot. The weather here in Michigan is warming up and it's been relatively dry. I've already replaced plugs and coils and crankshaft position sensor. Looking over the forum, it looks like it could be a High Pressure Fuel Pump. I looked for signs of damage to wires coming from pressure regulator valve, but I can't see any. Before I spend another $225 USD, does the scan below point to the HPFP?
Thanks in advance for all your help!!
Monday,03,May,2021,21:01:47:42410
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WVGZE77L97D016567 License Plate:
Address 01: Engine Labels: 03H-906-032-BLV.clb
Control Module Part Number: 03H 997 033 R HW: 03H 906 032 E
Component and/or Version: T 3.6-FSI-LEV2 G00 2374
Software Coding: 0001175
Work Shop Code: WSC 31414 790 00001
VCID: 3C21C8DF6A71FD47D5F-5184
7 Faults Found:
000135 - Fuel Rail/System Pressure
P0087 - 002 - Too Low - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 246161 km
Time Indication: 0
Freeze Frame:
RPM: 710 /min
Load: 32.9 %
Speed: 0.0 km/h
Temperature: 52.0°C
Temperature: 33.0°C
Absolute Pres.: 960.0 mbar
Voltage: 14.224 V
P0087 - 008 - Too Low - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 246161 km
Time Indication: 0
Freeze Frame:
RPM: 703 /min
Load: 32.1 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 33.0°C
Voltage: 14.224 V
008854 - Fuel Pressure Regulator Valve (N276)
P2296 - 001 - Short to Plus - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 0
Fault Frequency: 11
Reset counter: 255
Mileage: 246162 km
Time Indication: 0
Freeze Frame:
RPM: 191 /min
Load: 74.9 %
Speed: 0.0 km/h
Temperature: 89.0°C
Temperature: 52.0°C
Voltage: 10.668 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 246176 km
Time Indication: 0
Freeze Frame:
RPM: 1752 /min
Load: 77.6 %
Speed: 38.0 km/h
Temperature: 38.0°C
Temperature: 18.0°C
Voltage: 14.224 V
000774 - Cylinder 6
P0306 - 001 - Misfire Detected - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 246176 km
Time Indication: 0
Freeze Frame:
RPM: 1752 /min
Load: 77.6 %
Speed: 38.0 km/h
Temperature: 38.0°C
Temperature: 18.0°C
Voltage: 14.224 V
000772 - Cylinder 4
P0304 - 001 - Misfire Detected - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 246176 km
Time Indication: 0
Freeze Frame:
RPM: 1752 /min
Load: 77.6 %
Speed: 38.0 km/h
Temperature: 38.0°C
Temperature: 18.0°C
Voltage: 14.224 V
000773 - Cylinder 5
P0305 - 001 - Misfire Detected - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 246185 km
Time Indication: 0
Freeze Frame:
RPM: 3602 /min
Load: 98.8 %
Speed: 25.0 km/h
Temperature: 44.0°C
Temperature: 19.0°C
Voltage: 14.097 V
Readiness: 0100 0101
1 - 2 of 2 Posts
