1 - 14 of 14 Posts
I'm hoping someone can lead me to the right direction. I had the 30 sec shut off after startup. So i replaced both fuel pumps and the fuel filter (which was very dirty) and everything is back together. I open the driver door and I don't hear the pump priming at all. Engine turns over fine but wont start, and I stop it after a few seconds (I dont want to burn out my starter).
I pulled both 404 relays and try get same results.
I checked both 15Amp fuses both are good.
My battery is weak from me trying so much so I have to charge that now.(Its at about 11.8 Volts now.
My question is what else tells the pump to prime when you open the door?
I checked all the hoses are hooked up correctly, They seem to work only one way. Does the polarity mater on the green wire connector on the filter assembly?
Any help is greatly appreciated. Thanks in advance.
It sounds like only one of the fuel pumps is working. I am pretty sure that the 30 second cut off was a sign that only one of the two fuel pumps was pumping fuel. Seach the old threads as I am pretty sure that it was explained in one of them.
VW put out some PDF's that explained the theory behind the touareg systems. I am pretty sure that one of those training PDF's had a breakdown of the fuel system. Perhaps someone knows of the correct link and could post it here.
The Touareg Electrical System Design and Function
Self-Study Programme 298
Priming function of electrical fuel pump
The petrol engines of the Volkswagen Touareg all feature a priming function of the fuel pump so that enough pressure in the fuel lines can be built up.
Function:
When the driver's door is opened and terminal 15 is closed, a signal is sent via the CAN bus from the entry and start authorisation control unit J518 (terminal 15 off), a signal is also sent from the driver's door control unit J386 (driver's door opened) and, for reasons of safety, a discreet signal (status of terminal 15) is sent to the onboard power supply control unit J519. This then actuates the relay to prime the fuel pump for approx. 2 seconds. The priming function of the fuel pump is stopped when the ignition is switched on. Continued actuation is done through the engine control unit.
If the driver's door stays open, the actuation is repeated a maximum of three times in intervals.
Timed actuation from the onboard power supply control unit prevents continued actuation of the fuel pump if the driver's door is opened and closed a number of times in short intervals.
Crash shut-off
If with the ignition switched on a crash is detected, a signal is sent from the airbag control unit J234 via the CAN bus and the fuel pump is switched off immediately. After about 5 seconds it can be activated again by switching the ignition off and on.
Electric circuit:Onboard power supply management Key
G6 Fuel pump
J17 Fuel pump relay
J386 Driver's door control unit
J518 Entry and start authorisation control unit
J519 Onboard power supply control unit
J623 Engine control unit
Good, helpful research, NickyT.
I can give direct power to both pumps and they both work. I checked every fuse on the vehicle and swapped both 404 relay with others in the ebox. I get no power to the priming pump when the door opens. I scanned and have no codes either.
You need somebody with the Bentley cd manual to print out the procedure or to go up to VW site and take out a subscription to the online service manual.
I don't have access to either. :(
Hopefully someone will have access and print out the procedure for you.
PS: You are in deep enough here that you will have to own or have access to a VCDS if you are going to have any chance of fixing this on your own. If you are checking with codes with an OBD2 scanner, it ain't gonna work out for ya.
Discussion Starter #10
Update
I found the issue that I'm having. I decided to take everything apart and trace my steps. Looking at the fuel filter housing i noticed the two hoses on the left and right were full of fuel but the middle hose that goes to the passenger side was empty. I gave direct power to the filter housing and fuel was spraying out of the sides. Taking it apart again the o ring in the filter housing was pinched and not giving a tight seal allowing pressure to build in the housing to send fuel to both pumps. After reseating the oring between the top and bottom part of the housing the pump primes fine and touareg runs great.
You fixed it! That is great news.
I seem to remember that someone else posted in a fuel pump thread about having trouble getting the hoses seated correctly. Apparently it is a common problem.
That was a nice looking used fuel filter you had there. ;)
Discussion Starter #12
Yeah actually it was the large O-Ring for the fuel filter housing(Number 4 in the picture)
Anyone that has changed the internal filter and is having issues should recheck that. Thanks nickyt for your help it got my mind going to try to think of other things.
And yeah the old filter looked like a oil filter and that liquid was the fuel from inside the housing it was black.
2005 Touareg - 3.2L BMX
it doesnt make sense that a leaking fuel filter assembly would shut the power off to the connectors. or am i missing something??
Just noticed that fuse location 10 in the E-box (3.2L V6) is for fuel tank leak diagnosis, AC system high-pressure sensor and some other items. Perhaps a leak detection does shut off power to the pumps?
1 - 14 of 14 Posts
