1 - 3 of 3 Posts
Put new brake pads Turned rotors myself no sign of warped rotors.
Dialed in with light touch and cut 2 thousand on both sides no hi or low.
Now have wobble.
4200 ammco no new style adapter's chucked and turned striaght.
You should not be turning rotors. There is only 1mm wear on each side before they are undersize and out of service.
By wobble do you mean the tires or something with the brakes?
If you have a wobble perhaps you did not get the discs seated or the wheels are not seated.
Is this a T3 with possible steering wheel shake problems if the wheels were not installed per the TSB?
By the way that 1 MM is about 0.040" so the question is what is the total removed?
Front rotors new 32mm rear 28mm with a 2 mm wear limit or a little less than 0.080" from 1.259" front and 1.10" rear.
Wear limit front - 1.181"
Wear limit rear - 1.02"
If the discs were machined true with the center of the hub there must be some other problem existing.
1 - 3 of 3 Posts
