Thank.you guys for the suggestions but unfortunately neither of those worked :frowning:. Do you think it could.be the relay? And anybody know if it's a FYI type of fix? My car is falling apart this morning I turned car off to pump gas and it would start unless I stepped on the gas
Back when I started driving, the engine bay of my '66 1800S was full of $4 relays that turned stuff on and off.
The engine bay in your Touareg is full of $500+ ECUs that turn stuff on and off.
If you're planning on keeping the Touareg a while, either find a good private mechanic or invest in a Ross Tech setup -- software, laptop/tablet and genuine cable. It will go a long way to helping diagnose problems such as this.
Without diagnostic ability, you're just guessing at the problem. What you're describing now are symptoms.
