Sigh.. You've obviously not tried to find a front diff lock for the Touareg, let alone a factory fitted one!Sounds like the front diff is a questionable return on investment after marinating on some of the other valid points on this forum. If I were to go that route, I'd want to use the one that VW engineered for this vehicle... it is a thought though! I will continue to read and evaluate
Why ? Some people with no data have said the diff casing is too weak for a locking diff to be installed, I am not sure how a locking diff actually puts more load on the casing but thats their opinion based on visual inspection. Others have said with no data that Harrop are not a reputable engineering company and why buy from them. If you want the VW front or rear locking diff the first challenge is find one, the second is the price. The third challenge is get it to work with a vehicle that does not have the control modules and coding needed. The 4th is the long term reliability of the stepper motor and clutch based system adopted by VW. Easier to buy another Treg with locking diffs if you can find one I thinkSounds like the front diff is a questionable return on investment after marinating on some of the other valid points on this forum. If I were to go that route, I'd want to use the one that VW engineered for this vehicle... it is a thought though! I will continue to read and evaluate
That was exactly my concern. There are better vehicles suited for breaking things. Such as a hand me down Jeep from someone for $300 and a bottle of bootlegger's whiskey in Eastern Kentucky. However, this marvelous piece of German engineering is a formidable one and I'm not opposed to bringing mine where some people who shiver at bringing their rigs. That said, why break expensive things along the way if we don't have to? The lack of any data for or against this is a questionable return on investment, RIGHT NOW, but if some folks start getting these installed and using them to take their Touaregs where people can't already take their Touaregs, then I'll beWhy ? Some people with no data have said the diff casing is too weak for a locking diff to be installed, I am not sure how a locking diff actually puts more load on the casing but thats their opinion based on visual inspection. Others have said with no data that Harrop are not a reputable engineering company and why buy from them. If you want the VW front or rear locking diff the first challenge is find one, the second is the price. The third challenge is get it to work with a vehicle that does not have the control modules and coding needed. The 4th is the long term reliability of the stepper motor and clutch based system adopted by VW. Easier to buy another Treg with locking diffs if you can find one I think
In reality their are better off road vehicles with better suspension options if you're planning to go off road where you need locking diffs
Yes the cases are different because of the addition of the stepper motor to lock the diff, but do you know if the thickness of the casting is different to the locking vs non locking diff? I highly doubt it is. Thicker casting adds more weight to an already heavy car.Like I mentioned in one of my comments, I'd like to see engineering data comparing non-locking OEM front axle differential housing and a fully lockable OEM front axle housing.
The reason for that is I know for a fact that the rear locking and non-locking differential housings are different!
Also worth mentioning, most IFS trucks out there have relatively easy access to the front differential. This is no the case with subframe/unibody Touareg.
The surgery to install a locker in the front diff would be an undertaking that could potentially result in a catastrophic failure of a design not intended to be locked in the first place.
Also, the proximity of the front differential to engine oil pain which was necessitated by packaging created a potentially dangerous situation in the case of grenaded front differential.
You may find my reference to Toyota IFS front diff lockers anecdotal. And, be that as it may, I've seen some precarious results with modifications of systems not designed to be abused.
The aluminum alloy cast used in IFS off-road vehicles is nowhere near as strong as the weakest cast-iron or stamped center section of a solid axle.
Forearmed is forewarned.
Please can you post some photos of the internal differences? That would really put our minds at ease.I am not concerned with the locker itself.
It is plenty strong for a given application.
I don't bash neither Harrop nor ARB, there is no need. Both are fine manufacturers. I've used ARB product and it was superb!
The diff case is where my concern lies.
The rear locking diff is thicker where clutches and bearings are. The weight is not a concern, the strength is.
I hope whoever installs one in the Egg will conduct thorough testing and if failure occurs would share the findings.
Until then we are engaging in a futile conjecture.
P.S failure happens in the least anticipated moment.
I'd grenaded Dana44 front U-joint making multi point turn going up before trying slick rock obstacle @ Rubicon garden.
Everything was going great, last turn I was about to make and gave it a bit more throttle, mind you my Jeep had nearly 80:1 reduction (manual gearbox), and a lod pop followed by a jolt and a roll backwards. The only thing saved me from rolling down the hill, was my quick reaction to slam on the brakes.
It was long time ago, and I had a lunch-box locker inside D44.
The egg is too nice of a soft off-roader to even consider hard core trails.
I came to add your stuff to this thread after watching your video. Thanks for responding there...in case most of you missed it
