Just did the oil change that was coming due on my '10 TDI. Changed the fuel filter as well. I checked the transfer case fluid and it was fresh so I asked the PO about it. He said xfer case and diffs were done at 100K miles. I also asked about the tranny. He said it would be due at 160K, so it must have been done at 80K. Makes me feel much better about it now.
While I was under there, I checked a few more things out. I found a couple of things leaking. Not sure what they would be. Any ideas?
This is on the front driveshaft (prop shaft).
This is above the front diff/transmission, on the back of the engine.
Bellhousing (is it still called that on a VW??) above the axle. I can't tell if it is oil or transmission fluid at this point.
And not leak related, but this is one of the two noticeable faults in the interior. Any idea on what can be done with this?
