As we all know the AGM battery is fitted to these vehicles. The recommended maximum charging rate for an AGM battery is 0.4 C which for a 100Ah battery equates to 25A -The maximum charging current depends on the battery size, for a rough estimate of the max current in amps [A], divide the battery amp-hours [Ah] by 4 .
So theoretically a 230 Amp alternator can want to pump a significantly higher current into a battery with a remaining "say"60% charge. And that is also dependent upon battery temperature.
Since many people are getting 7+ yeas from an OEM battery VW must have some smarts there to limit the charge and look after the battery.
So my question is how VW maximise the service life of a battery. As far as I know the ECU /smart alternator function controls the voltage output of the alternator based on monitoring certain parameters... but as far as I know don't limit current.
Just to get one and all scratching their heads on a public holiday AUSTRALIA DAY....
