1 - 15 of 15 Posts
Just bought a VCDS scanner because my HVAC system went out. Ran a scan and pulled the following. At the moment, I am really only interested in clearing the HVAC codes and will get to the others eventually. I was wondering if anyone could help point me in the right direction on deciphering them. From what I've found here is that its likely the HVAC blower that needs replacing. Any input is appreciated.
08-Auto HVAC -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
69-Trailer -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: Malfunction 0010
Address 01: Engine (J623-CGRA) Labels:. 03H-907-309-V1.clb
Part No SW: 03H 906 023 B HW: 03H 907 309
Component: 3,6 FSI ULEV2 H15 8643
Revision: M7H15---
Coding: 002A0012433600000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM36FSI01103H906023B 002005
ROD: EV_ECM36FSI01103H906023B.rod
VCID: 211FECDF5145D433A0D-8074
8 Faults Found:
14627 - Fuel Pump Control Module
P025A 00 [040] - Electrical Fault
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 229
Mileage: 138226 km
Date: 2018.12.21
Time: 15:18:52
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 255 km/h
Coolant temperature: 17 °C
Intake air temperature: 15 °C
Ambient air pressure: 960 mbar
Voltage terminal 30: 11.355 V
Unlearning counter according OBD: 38
Fuel pump: specified value: 70.000 %
Low fuel pressure: specified value: 529.6 kPa
Fuel temperature: 18.0 °C
Fuel pump adaptation: 24.4 kPa
High fuel pressure: specified value: 6.9230 MPa
Fuel low pressure: actual value: 309.0 kPa
High pressure regulation: adaptation value: 0.0000 MPa
5582 - Oil Pressure Switch for reduced Oil Pressure
P164D 00 [032] - Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
12348 - Coolant Pump 2
P261A 00 [096] - Open circuit
4865 - No Communication with Towing System Control Module (J345)
U1003 00 [032] - -
[Towing recognition control module -J345No Communication]
9017 - Oxygen (Lambda) Sensor Signal B2 S2
P2273 00 [096] - too Rich
2921 - Knock Sensor 1 (G61)
P0328 00 [096] - Signal too High
2925 - Knock Sensor 2 (G66)
P0333 00 [096] - Signal too High
7666 - EVAP System
P0456 00 [096] - Very Small Leak Detected
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 AG HW: 7P6 907 040 AG
Component: Klima 2 Zonen H18 0613
Coding: 4606200A80
VCID: 79AFE4BF99556CF3C8D-802C
6 Faults Found:
0251 - Air Blower
B10BE 12 [008] - Short to Plus
[Frischluftgebläse Kurzschluss nach Plus]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 102
Reset counter: 44
Mileage: 189984 km
Date: 2021.04.05
Time: 12:25:56
0256 - Control Module for Air Blower
B10BB 96 [008] - Component internal failure
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 42
Mileage: 190995 km
Date: 2021.05.09
Time: 13:37:35
0258 - Control Module for Air Blower
B10BB 04 [008] - Internal System Fault
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 35
Mileage: 190650 km
Date: 2021.05.04
Time: 20:31:18
15360256 - Component Protection
U1101 00 [008] - Active
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 50
Mileage: 190678 km
Date: 2021.05.07
Time: 19:37:00
0309 - Local data bus 2
U1076 00 [009] - Electrical malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 63
Reset counter: 15
Mileage: 190789 km
Date: 2021.05.08
Time: 09:37:35
0243 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 45
Mileage: 191040 km
Date: 2021.05.11
Time: 07:40:14
Make sure the electrical system is working 100%, good alternator output and a full capacity fully charged battery. Then look at the motor & the wiring to it. Clear the codes and see what comes back.
Discussion Starter · #4 ·
1st, clear them and see if they return. Sometimes they return, sometimes its all good.
..and i think your battery is close to dead. This can trigger all the above problems.
Do you mean clear them in the open controller window? I did clear them for the HVAC controller, rescanned, and this is what came back. I wasn't sure I was doing it correctly since none of the original codes came back. If this is the correct way of doing it, I will clear the engine codes and rescan.
Coding: 4606200A80
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 68
Mileage: 192043 km
Date: 2021.06.07
Time: 11:33:29
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 28
Mileage: 192019 km
Date: 2021.06.02
Time: 19:32:26
Do you recommend buying a new battery, or charging it? Clearing the codes as in clearing it through the open controller window, right?
Sometimes VWs throw a lot of "fake" codes just because battery is done. First charge it, test it, then decide if you need a new one.
Some trouble codes dont come alone, they trigger other codes in different modules also. In general, if an error returns you need to adress it, if not..its all good.
If your battery is over 6 years then replace it or put in on charge overnight & test it first for 12.5v or more. Start with the easy things first. Clear the codes in VCDS top of my head it says erase all DTC`s . Then scan again. You may still have a fault but no point having several red herrings there to fool you.
Just replace it with OEM
Discussion Starter · #9 ·
I charged the battery overnight, cleared the DTCs, and rescanned. Only one code came back:
Coding: 4606200A80
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 192043 km
Date: 2021.06.08
Time: 12:10:53
Blower motor imho but I would locate it and see if the brushes are gunked up or worn ot and check for power. Don't rush into buying a new one. Where is it located? No idea but guessing down behind the glovebox area, take the glovebox out job.
I think the speed controller is part of the motor and not just a resister but a electronic SCR type. I will try & find the part number.
My brain is saying why no blower motor fault code?? Does the HVAC controls all work, light up as normal temp display change etc?? Show the blower speed? Just a thought but take it out & reseat the plugs maybe a bit of contact cleaner.
Discussion Starter · #14 ·
Yep, everything works as it should, just nothing blowing. It is located behind the glove box. I will try removing it and taking a look at everything.
2011 VR6 FSI LUX
Search Youtube for videos on changing the blower motor. There was one video I found that was helpful but it didn't allow for anyone to post a link to another site.
You should not have to remove your glove box. I think some people have change it out in under an hour.
1 - 15 of 15 Posts
