Haven't looked at this as I have air suspension but can you add air bags as a helper spring? Seems a bit of a waste to permanently stiffen up the rear end and spoil the ride when you aren't hitched up.
Unfortunately there are no aftermarket air-suspension options :-(Haven't looked at this as I have air suspension but can you add air bags as a helper spring? Seems a bit of a waste to permanently stiffen up the rear end and spoil the ride when you aren't hitched up.
there are heaps of options for both the 7L and also the CR, but so far I have not had success finding anything for a 7P - so frustratingHave you tried King Springs or another is Browns Spring Works in Melbourne. I put Kings in the rear and Browns in the front of my 7L a couple of years ago.
What about getting a hold of Eibach and getting them to suggest a suitable progressive rate set of springs.We have a 2012 Touareg 7P with spring suspension - we do a lot of towing and the rear of the car is starting to sag a bit too much - we want to put in firmer springs to help level it out but am finding hard to get springs in Australia - anyone have suggestions. ?. We are located in Perth but am happy to order online and get fitted locally if need be
thanks
There are also spring repair places that will retention your springs and make them a little stiffer.What about getting a hold of Eibach and getting them to suggest a suitable progressive rate set of springs.
There are spring manufactures that can make springs but you have to give them the specs.
Type of wire, thickness, spring rate, coil diameter yadayada.
