Hey guys!
I recently had an issue where the fan/blower motor stopped blowing. Regardless if I have the thermostat set to 72 or 84, nothing blows out. I just ran a VCDS scan and saw the following:
1 Fault Found:
0204 - Control Module for Air Blower
B10BB 16 [008] - Voltage Too Low
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 172
Reset counter: 197
Mileage: 115112 km
Date: 2016.02.17
Time: 17:05:37
Would you lean more towards replacing the resistor or the whole blower/fan? Not real sure where to go from here.
Thanks in advance!!
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 197
Mileage: 115112 km
Date: 2016.02.17
Time: 17:05:37
Thanks in advance!!
