1 - 3 of 3 Posts
my 2006 3.2 Touareg has a fault code of P0691 Fan control circuit low, fuse and relay are good, she heat up quickly and once I turn it off the fan stays on for a few min. I was thinking the water pump or thermostat might be bad, any suggestions?
So, both fans work without issue? The only thing I could think it would be is one of the fans being bad, but it could be possible that the thermostat is stuck closed.
Duff temp sensor.
1 - 3 of 3 Posts
