1 - 1 of 1 Posts
Anyone want to provide me with the ohm numbers from their fans (v8 or v6 should be the same)
Basically needs the resistance between the different wires, I believe brown and red are ground and full power/speed respectively, then the 2 middle wires are for low and middle speed/power.
I need to know what the ohm resistance is between ground and each wire.
Thanks!
1 - 1 of 1 Posts
