Tire pressure math! For offroad tires I run BFG A/T KO2 LT245/70R17 30.6" tires, and for on-road tires I run Goodyear Eagle LS2 265/50R19 110H, which are slightly bigger and much cheaper than stock. The KO2s are worth swapping out for non-offroad use, because they are loud, and handle poorly on twisty paved roads.
First, I figure out the psi/lb weight approximately for the factory tires by using the spec in this size for a Goodyear Eagle Touring 275/45R19/XL 108V:
2,205 lbs @ 50psi max pressure
50/2205 = 0.02267574 psi / lb
Next, I apply this to translate the factory pressures into approximate load weights:
Front factory spec is 39 psi:
41/0.0226757 = 1719.9 lbs
Rear factory spec is 46psi:
46/0.0226757 = 2028.603 lbs
Then, I find the psi/lb for the KO2 from BFG specs:
3000 lbs @ 80psi max
80/3000 = 0.02666667 psi / lb
Then I convert the factory weights to pressures for the KO2, rounded to the nearest psi:
Convert factory front spec:
1801.1 * 0.02666667 = approx 46 psi
rear spec:
2028.603 * 0.02666667 = approx 54 psi
Let's double check this load rating based method, and see what we get if we use math to keep the same length contact patch, in a narrower tire:
Front: 39psi*265/245 = approx 42psi
Rear: 46psi*265/245 = approx 50psi
So 4psi lower vs the load rating method... probably close enough either way.
Lastly, I do the same calculation for my Goodyear Eagle LS2 265/50R19 110H street tires:
2337lbs @ 50psi
50/2337 = 0.02139495 psi/lb
Front: 1719.9 * 0.02139495 = approx 37psi
Rear: 2028.603 * 0.02139495 = approx 43-44psi
Finally, I apply some common sense and decide that the spec of 2psi lower for the narrower LS2 tires doesn't make intuitive sense, and I will stay at the factory 39/46 value, especially since I tend to corner hard, and wear tires on the outside edges really quickly at low pressures. For the KO2s on road use, the 46/54 pressures do make a lot of sense to me- since they are narrower tires they will need more pressure at the same weight to keep about the same length contact patch. Offroad I will run these at 18-20psi.
