1 - 10 of 10 Posts
Hi,
I'm new here so thanks for letting me in.
I was hoping to pick your brains about an issue I have been having with my Touareg. First off, my Treg is 55 Reg (2005) V6 Petrol, converted to LPG.
I have been getting the ESP light on the dash intermittently and haven't worried much about it as I've not had any noticeable loss of traction. Today it came on again and I noticed that the PRND indicator on the dash is fully lit, i.e. it no longer shows me which gear I am in and the tiptronic also doesn't work.
I have also noted the steering has become heavier in the last few weeks.
I have read various posts about the ESP light on the forum here and some suggest it may be the MAF sensor. Do you think the symptoms I have listed are consistent with that diagnosis?
I am a little concerned that it may be a faulty ABS pump as I had that before in my old Golf Mk5 and had to fight tooth and nail to get VW to pay for a replacement. I really don't want to have to go through all that again!
So, before I go off to the dealer and pay for a VAG Com diagnostic, if anyone has any experience of these faults I'd be very grateful to hear your advice.
Many Thanks.
try to locate a friend nearby with VCDS or get the cable yourself. It pays for itself very quickly.
There could be a thousand things wrong. Getting it scanned will bring that down to a handful of possibles that can be easily traced if you know where to start.
ross-tech.com
Thanks for your reply.
Any idea where I can get that cable/software? As you can tell I'm no mechanic.
You could also buy something like this. VAG 409 1 OBD2 USB Auto Diagnostics Scanner VCDS Software for VW Audi | eBay
Use VCDS lite that is shareware from ross tech, they will not offer any support for these cables though. I have been using it for a few years and it has served me well. If you then want to upgrade the software to the full version this can be done for $99.
it does not go up to full version for $99. It releases some functionality within VCDS Lite
If you want to use the latest version of VCDS with long coding helper etc. you need to buy the original cable.
I have never needed anything more than the basic functionality, so I cannot comment on that.
Its been great for reading clearing error codes (Which is what the OP needs) and getting rid of seat belt chime. Also programmed my old car to talk properly to the towbar wiring.
The PRND issue has many threads about it if you search. It is usually caused by a problem with the circuit board under the shifter. There are a couple of magnets that easily dislodge and then the tiptronic function stops working. Had it happen to me last year. Cause was coins that found their way under the black shift mat apparently.
There is also a UK site
myTreg forums
where some members have VCDS which they will use on your car if you are local for a few beer tokens.
1 - 10 of 10 Posts
