21 - 40 of 50 Posts
Discussion Starter #21
In my case CEL is caused by gearbox error not by start/stop error. TCM finds the problem and sends information to ECM. Subsequently ECM turns on CEL.
The problem is:
P0C29 - Auxiliary Transmission Fluid Pump Driver Circuit Performance
I was thinking about it and in my opinion there may be 4 reasons:
1. Auxiliary Transmission Fluid Pump is broken
2. Auxiliary Transmission Fluid Pump Control Module is broken
3. Wire is broken (as you said "it could be as simple as a loose connection or a rotted\chewed wire")
4. Some relevant relay is broken
I'm just trying find the way how to find out which reason is right..
It's a DC motor.... connect power directly to it to bypass anything else.
The diagnostic equipment should be able to test (scan\communicate with) the module
Do a visual inspection. Use a meter to test for signal\continuity at the plug.
Start tracing the wiring diagram to locate said relay.
Discussion Starter #23
Thanks for this useful reply. I'm trying to find VW part number or the price of this Auxilliary transmission fluid pump but I cannot find it. Would you help me with that?
Discussion Starter #25
This number looks good but I have found only shops in America. I cannot find any shops from Europe using this part number. Probably there is different part number in Europe. But I cannot find it. If you are able to find it for Europe I would be grateful to you..
Discussion Starter #27
Thank you TurboABA, you are right. It's the same in Europe. When I started to search this number without spaces and with letter A on the end I have found results also in Europe (unfortunately not in my country). But the best price for new is about 600$ and for used is about 500$. I think it's too much money for something I don't really need. All the time I have this car when I started the engine I always turn off start/stop system before I started to drive.
You look that you know VCDS. Is it real to implement such a scenario?:
1 step: Turn off start/stop system using VCDS so the default position will be always OFF
2 step: Disable Auxilliary Transmission Fluid Pump using VCDS or disable Auxilliary Transmission Fluid Pump Control Module
The desired result should be no error messages on my dashboard..
Sounds feasible. We don't have the start/stop over here on our NA units... We get lots of stuff stripped off.
Discussion Starter #31
You mean that on european units should be start/stop system turning off available?
What is your current transmission coding?
You should be able to code it without the aux pump.
This will be under transmission coding, and then long coding.
I'm guessing that your 5th digit is going to be a 7, so something like 003178. If that is the case change the 5th digit to a 6 like 003168 and see if that helps
Discussion Starter #33
Thank you yrktreg. I have a question (I'm a newbie). Your described method is how to disable start/stop system or how to disable Auxilliary Transmission Fluid Pump as a device?
This will hopefully eliminate the aux pump error. The start stop system disable is a little more involved from what i've heard. I've never done one as we don't have it here in North America
Discussion Starter #37
If I change my transmission coding can it not affect the gearbox function? Not to worry?
It just tells the transmission control module that it is not equipped with the aux pump.
Should you have an error from the coding i'm telling you, you can always put it back :)
Discussion Starter #39
Hello yrktreg,
Finally I have found someone with VCDS and found out that my transmission coding is 001568. So unfortunately my 5th digit is not a 7. Do you have any idea what to change in my case to eliminate the aux pump error?
Hello yrktreg,
I'm sorry I don't since we don't have it in North America.
With that being said I am not very familiar with the 5 in your coding, but it is probably just for the gear display in the MFI
We normally have a 3 for no gear display, or a 1 for gear display
21 - 40 of 50 Posts
