Hey guys I just installed one of these after my tune and DPF delete proved too much for my stock one. Haha.
Took my driveshaft off because I had a V10 one I was going to use but turns out they are not the same.
So I ordered the VertexAuto mount. Gotta say for $350 you'd think they would put more thought into it. Haha. Using silicone hose instead of a more specific piece. Paying a premium for as advertised a superior fix than an new shaft or new bearing.
But none the less a way better fix and idea than replacing an OEM drive shaft with a similarly priced aftermarket driveshaft ($250-$380). And dealing with the cv joint and pressing the old bearing off is a pain and messy.
This could have been done easily without removing the shaft, and takes about 30min. So as far a labor to install a lot cheaper than labor to install a new bearing which involves removing and disassembling the drive shaft. Depending on what the shop might charge you to rebuild the shaft it might be cheaper to go with this bearing support clamp, and it lasts "forever" or at least a lot longer than another thin rubber mount.
It was super easy to install and so far the only thing I notice is a vibration around 35mph. No other noises or vibrations. And a good bit of piece of mind.
