1 - 3 of 3 Posts
Hi all just trying to get an clarification on whats required for Diffs, Transfer case, and Transmission oil requirements and its alternative to OEM.
The plan is to try and get it all in one place to help others as ive done a lot of reading and it all gets too much. any corrections and opinions are welcome and ill try to keep it all updated as best I can
T3 2011 TDI V6
Front Diff - G 052 145 A2 - 0.8L - Royal Purple 75w90 gear oil
Rear Diff - G 052 145 A2 - 1.25L - Royal Purple 75w90 gear oil
Transfer Case - G 052 515 A2 - 0.85L - Havoline DEXRON-VI Multi Automatic Transmission Fluid
Transmission - G 052 515 A2 - 10-12L - Havoline DEXRON-VI Multi Automatic Transmission Fluid
Is the above info correct?
Any additions/corrections are welcome and ill update
Discussion Starter · #2 ·
Just adding engine oil.
Engine Oil - 507.00 - Castrol Edge Pro LL03 5W-30
approved types are:
Castrol SLX Pro. LL03 5w-30 (in the gold bottle)
Mobil 1 ESP Formula 5W-30
Motul Specific VW 507
Total Quartz Ineo 5w-30 VW 507
AMSOIL European Car Formula 5W-30 Synthetic Motor Oil Low-SAPS (507.00)
Total 504/507
Pentosin Super Performance III
Liqui Moly Top Tec 4200
Blauparts have oil change kits include (oil,filter,and lower plug)
IDPARTS also has change kits for 10,000 / and 20,000.
surprised no one has said anything. would like to know if I'm on the right track
approved types are:
Total 504/507
yes spot on , all those oils are great, my 2010 has had Castrol Edge pro 5w30 fill on even service,(main dealer VW), 0-159000 and it purr's. now its out of warranty I change oil every 4-5 miles ,abit OCD but just want look after it, and now many oils meet the 507 spec, some far superior , add to your list (redline euro 5w30) easter based, and so on ,,
1 - 3 of 3 Posts
