The Watchdog monitors engine temperature via a simple thermistor attached to a suitable bolt on the waterpump or cylinder head, and twin units can also do oil or transmission temps. I had one on my old technology Landcruiser with a warning alarm setting. Many factory gauges sit on normal even when engine temp is obviously changing. I have seen a Landcruiser Gauge showing normal when the actual temperature has increased by around 20 degrees. All VWs I have owned seem to just sit on normal and give no indication of developing issues until perhaps too late.
Do late model Tregs have other alarms for things like temperature, radiator fluid level, gearbox temperature, oil temperature?
(Our Jetta has an oil temp function but I could not find anything on the Treg).
As I will be towing a van with my Treg I am particularly interesting in being able to monitor engine and gearbox temperatures.
