hello all I've got a big problem with my 2006 seaport auto 2.5
i went through a large puddle after a couple of miles it stopped
i turned the key a few times it started again
managed to get back home
got the glow plug light flashing orange and the engine management light is also on
i took the air filter out and it was wet at the bottom took all the plastic of dryer it all and put a new filter on
i also dried the sensor with air compressor and was told i could of damaged it so replaced with new sensor
it did start up put code reader on it came up with the following codes
18071pump injector controll short to b+ p1663
17084internal control module defective [c vag] p0700 intermittent
i am assuming that there is water in some of the electrics
can any one help me with this problem
as i do not have a clue were to look
i also took the ecu out under wipers and checked but was not wet at all
don't really want to take to deals as the cost would be to much
