Hello,
I hope there are some diagnostic masters out there who can point me in the right direction to get this issue resolved.
Thanks!!
Sunday,31,March,2024,10:56:58:24512
VCDS Version: 23.11.0.0 (x64) HEX-NET2 CB: 0.4643.5
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WVGEF9BP2GD009641 License Plate:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 3C 42 46 52 53 55 56 5F
62 65 69 6C 6D 72 85 8B 8E
VIN: WVGEF9BP2GD009641 Mileage: 139357km-86592miles
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
8E-Image Processing -- Status: OK 0000
Address 01: Engine (J623-CGRA) Labels:. 03H-907-309-V1.clb
Part No SW: 03H 906 023 CQ HW: 03H 907 309 E
Component: VR6 3.6l FSI H17 2137
Revision: M7H17--- CVN: 06CD1D30
Coding: 002A0012437600000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM36FSI01103H906023CQ 002003
ROD: EV_ECM36FSI01103H906023CQ.rod
VCID: 73B8B071EB30D492221-8026
VINID: 9E65D55894A00975000091840420AEEEC7
2 Faults Found:
4608 - Fuel Pressure Regulator Valve (N276)
P2294 00 [10101000] - Open Circuit
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 43
Mileage: 139350 km
Date: 2024.03.30
Time: 19:04:43
Engine RPM: 815.00 /min
Normed load value: 22.4 %
Vehicle speed: 0 km/h
Coolant temperature: 60 °C
Intake air temperature: 28 °C
Ambient air pressure: 950 mbar
Voltage terminal 30: 12.698 V
Unlearning counter according OBD: 40
Battery voltage: 12780 mV
Engine torque: 30.3 Nm
2838 - Fuel Rail/System Pressure
P0087 00 [11101000] - Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 139349 km
Date: 2024.03.30
Time: 19:03:27
Engine RPM: 1289.50 /min
Normed load value: 38.4 %
Vehicle speed: 24 km/h
Coolant temperature: 47 °C
Intake air temperature: 27 °C
Ambient air pressure: 960 mbar
Voltage terminal 30: 13.947 V
Fuel pump: specified value: 47.652 %
Low fuel pressure: specified value: 620.0 kPa
Fuel temperature: 39.0 °C
Fuel pump adaptation: 70.6 kPa
High fuel pressure: specified value: 7.1545 MPa
Fuel low pressure: actual value: 649.2 kPa
High pressure regulation: adaptation value: 0.0000 MPa
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0C8-927-7XX-V2.clb
Part No SW: 0C8 927 755 F HW: 0C8 927 755
Component: AL1000 AISIN 130 2885
CVN: DF9F4DF5
Coding: 010500000C008400000000000000000000000000
ASAM Dataset: EV_TCMAL991031 003118
ROD: EV_TCMAL991031_003.rod
VCID: 343A736DAEBE93AAFBB-8060
No fault code found.
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 R HW: 7P0 907 379 A
Component: MK25A H37 0521
Revision: -------- Serial number: 42905440682892 Dataset Number: 7P0012v____ 0001
Coding: 5B7613C349246F5CDAFAC89792D3F6607301
ASAM Dataset: EV_MK25AXT 010001
ROD: EV_ESPMK25A01000.rod
VCID: 4CCA0B8DD64EEB6A83B-8018
Part No SW: 4H0 907 064 GK HW: 4H0 907 064 GK
Component: BCM2 2.0 H37 0572
Revision: 00002001
Coding: 0D860016000000000000
VCID: 78A2875DF2D6B7CA173-802C
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H40 0046
Serial number: 3215000167368012
1 Fault Found:
00955 - Key 1
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 171
Mileage: 117230 km
Time Indication: 0
Date: 2023.08.21
Time: 14:36:51
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 CK HW: 7P6 907 040 CK
Component: Klima 2 Zonen H23 1507
Coding: 4686200880
VCID: 7F506C41D77880F2569-802A
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DA HW: 4H0 907 063 AA
Component: BCM1 2.0 H20 0311
Revision: 22020001 Serial number: 00001198679502
Coding: 2680C077973C5D010020480300005D4CC31C6608A2014261000000008040110000000000000000
VCID: 6A86AD15BC7A155A917-803E
Component: WWS 150811 033 0021
Serial number: 90243400151102152438
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 80709514
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 AC HW: 7P6 941 431 AC
Component: E1 - LDS H02 0040
Serial number: 00000000001111150029
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 00000000095Z0212D858
2 Faults Found:
00042 - Left Parking Light Lamp (M43)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 172
Mileage: 125143 km
Time Indication: 0
Date: 2023.10.26
Time: 09:36:33
00043 - Right Parking Light Lamp (M44)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 172
Mileage: 125143 km
Time Indication: 0
Date: 2023.10.26
Time: 09:36:33
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 D HW: 7N0 919 475
Component: PARKHILFE 8K H06 0030
Revision: -------- Serial number: 28261530202904
Coding: 310D04
ASAM Dataset: EV_VW526ParkiAssis2 001013
ROD: EV_VW526ParkiAssis2.rod
VCID: 44DA23ADFE1E232A4BB-8010
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 7P6 907 561 C HW: 7P6 907 561
Component: ACC3 H21 0400
Serial number: 00000000000000
Coding: 3701010101
ASAM Dataset: EV_AdaptCruisContrVW526 002012
ROD: EV_AdaptCruisContrVW526_002.rod
VCID: 3C2A5B4D86EE5BEA33B-8068
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 F HW: 7P0 959 655 F
Component: VW10Airbag02F H10 0044
Revision: -------- Serial number: 003S8001Z7PL Dataset Number: 7P6003V____ 1737
Coding: 000000000000000000000000000000003246
ASAM Dataset: EV_AirbaVW10BPAVW526 002001
ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
Seat occupied recognition:
Serial number: 5850000R159100NULE
Serial number: 3575LRB400K5576669U5
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585LRB400S55766918U
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3517ARB404T3PH3AC0LK
Passenger side rear thorax airbag crash sensor:
Serial number: 3527ARB404T3PH3AEO3T
Serial number: 3557BRB404T3M92EF1RR
Serial number: 3567BRB404T3M92E48QN
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 M HW: 7P6 953 507 AJ
Component: Lenks.Modul H06 0010
Revision: -------- Serial number: 01374OKF00011
Coding: 000CDD
VCID: 3D2C56499D7452E2045-8068
Subsystem 1 - Part No SW: 7P6 959 542 A HW: 7P6 959 542 A
Component: E221__MFL-TAS H04 0028
Serial number: 0109234 TRW 20151019
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 983 C HW: 7P6 920 983 C
Component: Kombi H13 0515
Revision: 13240304 Serial number: 658061115592020
Coding: 834732026F08CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001022
ROD: EV_KombiUDSRBVW526.rod
VCID: 3FD02C4197F840F2169-806A
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 7P6 907 530 N HW: 7P6 907 530 G
Component: GW-CAN-L-FR-M H13 6042
Revision: -------- Serial number: 00000002040156 Dataset Number: 7P6067v____ 0041
Coding: 0021035600
GVL: FB5F40251D7F680000
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
VCID: 43D820B1FB102412721-8016
Subsystem 1 - Part No SW: 7P0 915 181 B HW: 7P0 915 181
Component: Batt_Sensor H07 0190
Serial number: 42286A27355701873890
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 7P6 907 566 A HW: 4H0 907 566 F
Component: SWA Master H07 0030
Serial number: 0386652823 Dataset Number: 7P6764V____ 0009
Coding: 030221
ASAM Dataset: EV_LaneChangAssis 001028
ROD: EV_LaneChangAssis_VW51.rod
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 7P6 907 568 A HW: 4H0 907 568 F
Component: SWA Slave H07 0030
Serial number: 0385949059
Coding: 030221
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4H0 959 793 AC HW: 4H0 959 793 P
Component: TSG FA H02 0306
Revision: -------- Serial number: 0000174989070
Coding: 011D17200000453005080001
VCID: 7AA69D55CCDAA5DA617-802E
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0384192173
Coding: 01871E3A68B95001C3B00620210A18000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 A HW: 7P6 959 719 A
Component: GTO BT H20 0059
Serial number: 288156755
Subsystem 2 - Part No: 1K0 951 605 C
Subsystem 3 - Part No SW: 3AA 962 243 E HW: 3AA 962 243 E
Component: GEB.F.Heckoef H16 0813
Serial number: 65044497
1 Fault Found:
01134 - Alarm Horn (H12)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 187
Mileage: 127846 km
Time Indication: 0
Date: 2023.11.08
Time: 10:20:29
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4H0 959 792 S HW: 4H0 959 792 M
Component: TSG BF H02 0306
Revision: -------- Serial number: 0000174477790
Coding: 011D17200000453005080000
VCID: 48C2379DC2B6074AA73-801C
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C15B0600591 Dataset Number: A001
Coding: 01040200
ROD: EV_ParkbA7.rod
VCID: 363E4965B8C281BAC5F-8062
Slave 3:
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Revision: -------- Serial number: -------------- Dataset Number: 7P0036v____ 0019
Coding: 012A02010B000400
ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001
ROD: EV_HeadlRegulAFSMQBMLB_VW51.rod
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0005
Coding: B00000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0005
Coding: B00000
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156K20F2520967
Coding: 020007020000000001
VCID: 241A832D1EDE032A6BB-8070
Part No SW: 7P6 035 664 L HW: 7P6 035 664 A
Component: H-BN-NA H41 0954
Revision: -------- Serial number: 606K+0F7515612
Coding: 010200050040E9EF39022B0E00000003F00001030000000000
VCID: 41D42AB9E18C360260D-8014
Subsystem 1 - Part No: 7P6 060 884 D
Component: NAR 2016 1302
Subsystem 2 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Component: DU8 SV Touch H56 0046
Serial number: VWZ8Z9RGG006H8
Subsystem 3 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Subsystem 4 - Part No: 8R0 060 961 G
Component: CD-Database 6890
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 P HW: 4H0 959 795 J
Component: TSG HL H03 0306
Revision: -------- Serial number: 0000175151451
Coding: 011817200000253005080000
Part No SW: 7P6 907 273 L HW: 5Q0 907 273
Component: RDKBERU30 H04 0003
Serial number: 40000000030124 Dataset Number: 7P6096V____ 0029
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30_005.rod
VCID: 45DC3EA9F5241A225C5-8010
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4H0 907 383 M HW: 4H0 907 383 K
Component: Anhaenger H20 0160
Revision: 7C001003 Serial number: 0384709255 Dataset Number: 7P0124v____ 0008
Coding: 0200000200000000
ASAM Dataset: EV_TrailFunctGener2Hella 001005
ROD: EV_TrailFunctGener2Hella_VW52.rod
VCID: 37204461BFC878B2DE9-8062
Address 6C: Back-up Cam. (J772) Labels:* Redir Fail!
Part No SW: 7P6 980 556 HW: 7P6 980 556
Component: RVC Compact H08 0160
Coding: 0125060123002003000040
ASAM Dataset: EV_CamSysRVRVCPANAVW526 001001
ROD: EV_CamSysRVRVCPANAVW526.rod
VCID: 7EAE9145D07289FA5DF-802A
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 310501540 Dataset Number: 7p0771v____ 0012
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202142
ROD: EV_HeckkTouar.rod
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0306
Revision: -------- Serial number: 0000175186860
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 7P6 907 217 B HW: 7P6 907 217
Component: DPC-SG H26 0035
Revision: -------- Serial number: 262130025421000 Dataset Number: 7P0EZ1v____ 0024
Coding: 69020000
ASAM Dataset: EV_OnBoardCamerDTR 001001
ROD: EV_OnBoardCamerDTR.rod
VCID: 3924425989DC6EC228D-806C
Slave 1:
Subsystem 1 - Part No: 7P6 907 658
Component: NICKRATENSENS H02 0001
Serial number: 000000007066966_3174
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 7P6 907 541 C HW: 7P6 907 541
Coding: 3701010101
ASAM Dataset: EV_AdaptCruisContr2VW526 002011
ROD: EV_AdaptCruisContr2VW526_002.rod
VCID: 3A265D558CDA65DA217-806E
Address 8E: Image Processing (J851) Labels:| 7P6-907-107.clb
Part No SW: 7P6 907 107 B HW: 7P6 907 107
Component: BV-SG H33 0035
Serial number: 005000010911157
Coding: 0AA118040000
ASAM Dataset: EV_BTR 002001
ROD: EV_BTR_002.rod
End----------(Elapsed Time: 02:16, VBatt start/end: 12.0V/12.2V)-----------
Thanks!!
www.Ross-Tech.com
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 43
Mileage: 139350 km
Date: 2024.03.30
Time: 19:04:43
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 139349 km
Date: 2024.03.30
Time: 19:03:27
CVN: DF9F4DF5
Revision: 00002001
1 Fault Found:
00955 - Key 1
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 171
Mileage: 117230 km
Time Indication: 0
Date: 2023.08.21
Time: 14:36:51
Coding: 4686200880
Coding: 004DBD
Coding: 025223
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 172
Mileage: 125143 km
Time Indication: 0
Date: 2023.10.26
Time: 09:36:33
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 172
Mileage: 125143 km
Time Indication: 0
Date: 2023.10.26
Time: 09:36:33
Coding: 310D04
Coding: 3701010101
Coding: 000CDD
Coding: 0021035600
Coding: 030221
Coding: 030221
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 187
Mileage: 127846 km
Time Indication: 0
Date: 2023.11.08
Time: 10:20:29
Coding: 01040200
ROD: EV_ParkbA7.rod
Slave 3:
Coding: B00000
Coding: B00000
Coding: 0533314003
Coding: 69020000
Slave 1:
Coding: 3701010101
ROD: EV_BTR_002.rod
