Good day to you all
My wife's Q5 TDI developed an interesting problem. Yes, I realize it is not Touareg but this is likely the forum with the most technically saavy folks, so trying out for ideas of what can be wrong / what to check.
In the morning, after the night in the garage, when pulling out of the driveway, I noticed (she reported it, and I confirmed it) that switching from reverse to drive and pressing the accelerator, the car jerks and there is a visible thud, not too loud, but it seems like something engages rather heavily. The car is shy of 48k mile marker, so I'd hope this is not transmission giving up on us. No error codes on VCDS, the car was scanned multiple times. The problem does not go away when the engine is warm, it is just less noticeable. I also noticed it is more visible when going uphil, as if something had problems engaging into drive. No issues I can see in between gears when already in drive.
The second issue is even more bizarre. In the morning, when driving out of the community we live in, and pulling up at the stop sign, I press the brake to stop the car and it seems like transmission is fighting me to the point where I get into panic mode since it feels like brakes are not there. I have to press the brakes deeper to make the car stop. The engine downshifts correctly but it seems like the transmission does not disengage correctly and keeps on pulling the car despite me pressing the brake. This problem seems to disappear as the engine / transmission warms up, but seems to be back when leaving work in the afternoon and going home. Again, the car was scanned many times and no error codes of any sort.
It seems like it is the start of some transmission problems, and while the whole thud thing is not bothersome, the brake problem is more and more concerning. I check the brake pads, rotors, discs, and all looks fine. Brakes engage correctly as far as I can tell, but it seems like the car is fighting me when braking cold.
Thanks for any thoughts / hints. I hope this is not the start of a terror story similar to what I was running into with my Touareg a while back.
On the flip side, the gas Q5 is running just fine, with no issues. I seem to have bad luck with anything diesel-powered.
