1 - 4 of 4 Posts
I launched my boat today, and, as one does, reversed it down the ramp into the water. I realized it submerged the tailpipes for a second, because I could hear a burble, but I quickly corrected.
I then got then got the boat all squared away, and onto it's mooring, and by the time I got back, maybe 2 - 2.5 hrs had past. When I started the car with the empty trailer attached it flashed engine fault and had a quirly q on the tach and one flashing on top of the MFD.
I got to my storage place to dump the empty trailer (20 min drive) and turned off the car to take trailer off. When I turned it back on all was fine...or is it? What happened?! Has this happened to anyone else?
These things are designed to drive through water/mud nearly halfway up the doors. Submerging the exhaust pipes for a few minutes with the engine running should NOT have triggered any faults. The curly-q symbol usually means a glow plug issue and, if flashing, an important engine MIL - malfunction indicator light - was set. The ECU should have stored the event. Get a VCDS readout to find out what it was, clear it, and see if it returns. If the code repeats you have more to go on.
submerging tail pipe for a short time will do no harm, BUT if you are dealing with salt water you best do a real good jovb of flushing the whole area that went under, like brakes wheels etc. Your exhaust blew out the water that may have entered the pipes.
What he said. That's why you never stop the engine when the pipes are submerged.....
1 - 4 of 4 Posts
