2010 Touareg TDI base model. I've owned for 4years and 40k miles with minimal problems (replaced: coolant tank, battery, power steering pump, front lower/upper control arms, relays in steering column lock mechanism, both intake flapper valves under warranty)
I was driving and the engine just cut out, no sputter, just stopped. there are no warning lights on. when I try to start it just cranks with no combustion. The high pressure fuel pump belt is good. it seems like the electric fuel pump is running when I turn on the ignition, but not 100% sure.
Here Is the VCDS scan. I edited it to remove the modules with no errors. These are my pre existing conditions: The radio has been replaced with after market and I recently installed a factory hitch with trailer module which I didn't do any coding on and haven't tested either so that is two of the errors. The CAN programming error showed up after bringing to the dealer for a SCR light that came on but everything seemed to work so I ignored it. The parking sensors errors are likely due to my hitch mounted spare tire, which blocks several of the sensors. The rear hatch doesn't open 50% of the time, I think it is the release mechanism.
Any suggestions on what to look at would be helpful.
Thanks in advance.
Friday,13,September,2024,17:40:21:46567
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240429 DS355.0
www.Ross-Tech.com
VIN: WVGFK7A9XAD001494 License Plate:
Mileage: 236860km-147177mi Repair Order:
Chassis Type: A9 (6N0)
Scan: 01 02 03 05 08 09 0F 15 16 17 19 1C 22 46 65 68 69 6D 6E 76
77
VIN: WVGFK7A9XAD001494 Mileage: 236860km-147177miles
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
0F-Digital Radio -- Status: Not registered 0001
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: OK 0000
22-AWD -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
68-Wiper Electr. -- Status: OK 0000
69-Trailer -- Status: Not registered 0011
6E-Ctrl Head Roof -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Not registered 0001
Address 0F: Digital Radio
Cannot be reached
Address 19: CAN Gateway Labels:. 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 7L6 920 972 A
Component: J533 GW-K-CAN TP20 9833
Coding: 57E2F79901066002
Shop #: WSC 31414 790 00001
VCID: 70B9D78346A84DFAA73-8024
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 121
Mileage: 234017 km
Time Indication: 0
Date: 2024.07.17
Time: 10:54:20
Address 46: Central Conv. Labels: 7L0-959-933.clb
Part No: 7L6 959 933 A
Component: 4M HSG 0601
Coding: 0000085
Shop #: WSC 25152 444 53719
VCID: 40D9474336989D7A173-4B1E
Subsystem 1 - Part No: 7L0 959 701 M
Component: Tuersteuergeraet FS 6304
Subsystem 2 - Part No: 7L0 959 702 M
Component: Tuersteuergeraet BF 6304
Subsystem 3 - Part No: 7L0 959 703 C
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 C
Component: Tuersteuergeraet HR 0201
5 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
00896 - Trunk Lock Unit (F256)
008 - Implausible Signal - Intermittent
01134 - Alarm Horn (H12)
000 - -
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
00931 - Locking Module for Central Locking; Rear Right (F223)
Address 65: Tire Pressure Labels:. 7L6-907-273.lbl
Part No SW: 7L6 907 273 E HW: 7L6 907 273 E
Component: J0502 RDK 0006
Revision: 00004006 Serial number: 00000900015304
Coding: 04D80011770000000000000000
VCID: 3A2D35AB5014C7AA597-806E
1 Fault Found:
02214 - Tire Pressure Warning
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 182
Mileage: 235652 km
Time Indication: 0
Date: 2024.08.09
Time: 10:28:30
Freeze Frame:
(no units): 63.0
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 G HW: 7L0 907 383 G
Component: ANHAENGERELEKTRONIK 8854
Coding: 0000002
Shop #: WSC 31414 000 00000
VCID: 38292FA36E18D5BAAF3-806C
1 Fault Found:
00576 - Terminal 15
Freeze Frame:
Count: 0
Count: 0
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0L Einparkhilfe 1108
Shop #: WSC 00000 000 00000
VCID: 392F2AA75512CCB250D-806C
3 Faults Found:
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
014 - Defective
00437 - Rear Right Inner Parking Aid Sensor (G335)
014 - Defective
00436 - Rear Left Inner Parking Aid Sensor (G334)
014 - Defective
End----------(Elapsed Time: 02:12, VBatt start/end: 12.2V/12.2V)-----------
Thanks in advance.
www.Ross-Tech.com
77
Cannot be reached
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 121
Mileage: 234017 km
Time Indication: 0
Date: 2024.07.17
Time: 10:54:20
Coding: 0000085
5 Faults Found:
000 - -
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 182
Mileage: 235652 km
Time Indication: 0
Date: 2024.08.09
Time: 10:28:30
Freeze Frame:
(no units): 63.0
Coding: 0000002
1 Fault Found:
00576 - Terminal 15
Freeze Frame:
Count: 0
Count: 0
3 Faults Found:
014 - Defective
014 - Defective
014 - Defective
