Friday,27,December,2024,13:41:30:16503
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.5
Data version: 20240919 DS356.3
[URL='http://www.Ross-Tech.com']www.Ross-Tech.com[/URL]
VIN: WVGEP9BP3FD007568 License Plate:
Mileage: 291818km-181327mi Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 36 3C 42 46 52 53 55 56
5F 62 65 69 6C 6D 72
VIN: WVGEP9BP3FD007568 Mileage: 291818km-181327miles
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Not registered 0011
08-Auto HVAC -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Cannot be reached 0100
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 7P1 907 401 C HW: 7P0 907 401 K
Component: 3.0TDI FSA H21 0010
Revision: 56H21--- CVN: AF4B74E538D3FF82755A21130E1FC39E
Coding: 292A4012233600050000
Shop #: WSC 28997 004 1048576
ASAM Dataset: EV_ECM30TDI0117P1907401C 001011
ROD: EV_ECM30TDI0117P1907401C.rod
VCID: 303ECF870AA754FAEFB-8064
VINID: 9E65D58094A00D65000071462064085F98
2 Faults Found:
9954 - NOx Reductant Consumption too Low
P20F4 00 [10101111] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 291791 km
Date: 2024.12.27
Time: 09:53:51
Engine RPM: 1613.50 /min
Normed load value: 76.5 %
Vehicle speed: 98 km/h
Coolant temperature: 94 °C
Intake air temperature: -3 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.840 V
Unlearning counter according OBD: 40
Long-term adaptation of reduction agent dosage: 1.81
Measured NOx conversion range 1: 0.000
Efficiency threshold of NOx conversion range 1: 0.000
Mean temperature of SCR catalyst: 303.2 °C
NOx sensor 1: NOx concentration: 1163 ppm
NOx sensor 2: NOx concentration: 516 ppm
Particle filter: unburned fuel calculated: 0.001
17277 - SCR NOx Catalyst Bank 1
P20EE 00 [01100000] - Efficiency too Low
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 291689 km
Date: 2024.12.23
Time: 09:20:27
Engine RPM: 1311.00 /min
Normed load value: 57.3 %
Vehicle speed: 55 km/h
Coolant temperature: 87 °C
Intake air temperature: -9 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.780 V
Unlearning counter according OBD: 39
SCR efficiency test overall: 0.00 %
SCR error threshold of efficiency test: 45.00 %
SCR efficiency test 2: 0.268
SCR efficiency test 1: -1.056
Particle filter: unburned fuel calculated: 0.008
Mean temperature of SCR catalyst: 258.1 °C
Long-term adaptation of reduction agent dosage: 0.98
Readiness: 1 1 0 1 0
Address 02: Auto Trans (J217) Labels: 0C8-927-7XX-V2.clb
Part No SW: 0C8 927 755 R HW: 0C8 927 755
Component: AL1000 AISIN 130 3374
CVN: E0C27B10
Coding: 010200000C008400000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_TCMAL991031 003118
ROD: EV_TCMAL991031_003.rod
VCID: 40DE9F47BA07C47A1FB-8014
No fault code found.
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 R HW: 7P0 907 379 A
Component: MK25A H37 0521
Revision: -------- Serial number: 40175438915579 Dataset Number: 7P0012v____ 0001
Coding: 5B7613C34924255ADAF9C89992DAA4607301
ASAM Dataset: EV_MK25AXT 010001
ROD: EV_ESPMK25A01000.rod
VCID: 4CC6BB77864F101AF33-8018
Part No SW: 4H0 907 064 FK HW: 4H0 907 064 EK
Component: BCM2 2.0 H36 0560
Revision: 00002001
Coding: 0D860016000000000000
VCID: 77AC349BAFC943C26E1-8022
Subsystem 1 - Part No SW: 7P6 959 754 AR HW: 7P6 959 754 AR
Component: FBSTOUAREGIDG H08 0084
Serial number: 3615000146800001
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H40 0046
Serial number: 3215000067512006
2 Faults Found:
00192 - Rear Left Door Handle Touch Sensor (G417)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 2
Fault Frequency: 1
Reset counter: 248
Mileage: 291370 km
Time Indication: 0
Date: 2024.12.16
Time: 10:14:18
03283 - Antenna for Access & Start Authorization; Left
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 248
Mileage: 291401 km
Time Indication: 0
Date: 2024.12.16
Time: 11:30:48
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-BFS H08 0156
Revision: AA000000 Serial number: 00000142207465
Coding: 00581B0000004001000001010101202020202121202020
VCID: 3436C397FE3F68DA8B3-8060
3 Faults Found:
02005 - Coding Pin
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 229
Mileage: 290795 km
Time Indication: 0
Date: 2024.10.10
Time: 10:10:05
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 229
Mileage: 290795 km
Time Indication: 0
Date: 2024.10.10
Time: 10:10:05
01964 - Control Module for Seat & Steering Column Memory (J136)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 229
Mileage: 290795 km
Time Indication: 0
Date: 2024.10.10
Time: 10:10:06
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 CD HW: 7P6 907 040 CD
Component: Klima 2 Zonen H23 1406
Coding: B606200A80
VCID: 78AE37A7A2574CBA67B-802C
1 Fault Found:
0320 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 248
Mileage: 291370 km
Date: 2024.12.16
Time: 10:13:31
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DA HW: 4H0 907 063 AA
Component: BCM1 2.0 H20 0311
Revision: 22020001 Serial number: 00001065168702
Coding: 26000096963C5D010020480300005D4C431C6608A2010261000000008040110000000000000000
VCID: 6A8A1DEFEC7BEE2AE1F-803E
Component: WWS 150416 033 0021
Serial number: 90243400150422150021
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 20539702
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 AC HW: 7P6 941 431 AC
Component: E1 - LDS H02 0040
Serial number: 00000000002004150167
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 00000000095Z01E7EC77
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 D HW: 7N0 919 475
Component: PARKHILFE 8K H06 0030
Revision: -------- Serial number: 28291509801705
Coding: 310504
ASAM Dataset: EV_VW526ParkiAssis2 001013
ROD: EV_VW526ParkiAssis2.rod
VCID: 44D69357AE1FD85A3B3-8010
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 E HW: 7P0 959 655 E
Component: VW10Airbag04Z H10 0043
Revision: -------- Serial number: 003NK003B6VB Dataset Number: 7P6003V____ 1649
Coding: 00000000000000000000000000000000345A
ASAM Dataset: EV_AirbaVW10BPAVW526 002001
ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
VCID: 43D4904BAB11DF62029-8016
Seat occupied recognition:
Serial number: 5850000R152060JX2D
Serial number: 3575LRB405V378TQ905Y
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585LRB4055378C6COB5
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3517ARB405J378CIK9IF
Passenger side rear thorax airbag crash sensor:
Serial number: 3527ARB405H378CI4P95
Serial number: 3557BRB404R36FA07PLJ
Serial number: 3567BRB404P36FA0JG88
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 L HW: 7P6 953 507 AF
Component: Lenks.Modul H06 0005
Revision: -------- Serial number: 01374ODC000M3
Coding: 0000D5
VCID: 3C26EBB7D66FA09A433-8068
Subsystem 1 - Part No SW: 7P6 959 542 A HW: 7P6 959 542 A
Component: E221__MFL-TAS H05 0028
Serial number: 0029962 TRW 20150317
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 983 A HW: 7P6 920 983 A
Component: Kombi H13 0515
Revision: 13240302 Serial number: 658280415592023
Coding: 8B7733022B08CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001022
ROD: EV_KombiUDSRBVW526_VW52.rod
VCID: 3D20E6B3CDF5A99274D-8068
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 7P6 907 530 M HW: 7P6 907 530 F
Component: GW-CAN-L-MOST H13 6042
Revision: -------- Serial number: 00000001827566 Dataset Number: 7P6067v____ 0041
Coding: 000103AD00
GVL: FB4F40651D7F000000
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
VCID: 42DA954FB40BD66A09F-8016
Subsystem 1 - Part No SW: 7P0 915 181 B HW: 7P0 915 181
Component: Batt_Sensor H07 0190
Serial number: 42103E04575701849439
2 Faults Found:
5274 - Seat/Mirror Postion Control Module - Driver
U0208 00 [00001001] - No Communications
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 248
Mileage: 291370 km
Date: 2024.12.16
Time: 10:13:32
Voltage terminal 30: 11.7 V
Voltage terminal 15: 11.7 V
Control Module temperature: 26 °C
System status: Terminal 15 on
IN ESP_standstill flag: standstill detected
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 0
0021 - Control Module Incorrectly Coded
U1014 00 [00001001] - -
[Steuergerät falsch codiert (CAN)]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 31
Reset counter: 3
Mileage: 291370 km
Date: 2024.12.16
Time: 10:13:32
Control Module temperature: 27 °C
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
Address 36: Seat Mem. Drvr
Cannot be reached
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 7P6 907 566 A HW: 4H0 907 566 F
Component: SWA Master H06 0021
Serial number: 0366295507 Dataset Number: 7P6764V____ 0009
Coding: 030221
ASAM Dataset: EV_LaneChangAssis 001028
ROD: EV_LaneChangAssis_VW52.rod
VCID: 3FDC9CBBC7F9BB82661-806A
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 7P6 907 568 A HW: 4H0 907 568 F
Component: SWA Slave H06 0021
Serial number: 0365174819
Coding: 030221
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4H0 959 793 AC HW: 4H0 959 793 P
Component: TSG FA H02 0306
Revision: -------- Serial number: 0000147218161
Coding: 011D17205E00453005080000
Shop #: WSC 50435 001 1048576
VCID: 7AAA2DAF9CDB5EAA11F-802E
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 3
Mileage: 291370 km
Time Indication: 0
Date: 2024.12.16
Time: 10:13:32
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0366807744
Coding: 0187123A68B9509580A00620210A18000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 A HW: 7P6 959 719 A
Component: GTO BT H20 0059
Serial number: 026152627
Subsystem 2 - Part No: 1K0 951 605 C
Subsystem 3 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.062 H01 0008
Serial number: WOO3499803A
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.062 H01 0008
Serial number: WOO34960411
Coding: 191100
Subsystem 5 - Part No SW: 3AA 962 243 E HW: 3AA 962 243 E
Component: GEB.F.Heckoef H16 0813
Serial number: 65016117
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4H0 959 792 S HW: 4H0 959 792 M
Component: TSG BF H02 0306
Revision: -------- Serial number: 0000146964520
VCID: 48CE876792B7FC3AD7B-801C
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 3
Mileage: 291370 km
Time Indication: 0
Date: 2024.12.16
Time: 10:13:32
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C1542100947 Dataset Number: A001
Coding: 01040200
ROD: EV_ParkbA7.rod
VCID: 3632F99FE8C37ACAB57-8062
Slave 1:
Slave 3:
6 Faults Found:
0001 - Control Module Overtemperature Condition
P0634 00 [00001000] - -
Freeze Frame:
Fault Frequency: 1
Reset counter: 254
Mileage: 291580 km
Date: 2024.12.20
Time: 16:33:59
Voltage: 13.6 V
0052 - Parking Brake Motor; Right
C10BD 07 [00001000] - Mechanical Failure
[Aktuator EPB - Blockierter Motor - Rechts]
Freeze Frame:
Fault Frequency: 2
Reset counter: 254
Mileage: 291580 km
Date: 2024.12.20
Time: 16:08:18
Voltage: 13.4 V
0004 - Parking Brake Motor; Left
C10BC 07 [00001000] - Mechanical Failure
[Aktuator EPB - Blockierter Motor - Links]
Freeze Frame:
Fault Frequency: 1
Reset counter: 254
Mileage: 291580 km
Date: 2024.12.20
Time: 16:33:57
Voltage: 11.8 V
0025 - No Calibration
B2010 F0 [00001000] - Deviation from Expected Range
[Steuergerät EPB - Kalibrierung fehlgeschlagen]
Freeze Frame:
Fault Frequency: 1
Reset counter: 254
Mileage: 291580 km
Date: 2024.12.20
Time: 16:08:16
Voltage: 14.6 V
0051 - No Calibration
[Steuergerät EPB - Kalibrierung fehlgeschlagen Luftspiel]
Freeze Frame:
Fault Frequency: 1
Reset counter: 254
Mileage: 291580 km
Date: 2024.12.20
Time: 16:08:17
Voltage: 14.0 V
0024 - No Basic Setting
B2010 00 [00001001] - -
[Steuergerät EPB - System nicht kalibriert]
Freeze Frame:
Fault Frequency: 1
Reset counter: 254
Mileage: 291580 km
Date: 2024.12.20
Time: 16:04:26
Voltage: 13.8 V
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Revision: -------- Serial number: -------------- Dataset Number: 7P0036v____ 0016
Coding: 012A02010B000400
ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001
ROD: EV_HeadlRegulAFSMQBMLB_VW52.rod
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0005
Coding: B00000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0005
Coding: B00000
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156D+0F8255392
Coding: 020007020100000001
VCID: 241633D74EDFF85A1B3-8070
Part No SW: 7P6 035 664 G HW: 7P6 035 664 A
Component: H-BN-NA H40 0881
Revision: -------- Serial number: 273DV0FB007006
Coding: 010200050040E1EF51022B0E00000003F00001030000000000
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015 1102
Subsystem 2 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Component: DU8 SV Touch H53 0046
Serial number: VWZ8Z9RX8004F1
Subsystem 3 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Subsystem 4 - Part No: 8R0 060 961 G
Component: CD-Database 5950
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 4
Reset counter: 39
Mileage: 291580 km
Time Indication: 0
Date: 2024.12.20
Time: 15:14:20
Freeze Frame:
Bin. Bits: 00000000 00000000
Bin. Bits: 00000000 00000001
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 P HW: 4H0 959 795 J
Component: TSG HL H03 0306
Revision: -------- Serial number: 0000147254421
Coding: 011817200000253005080000
Part No SW: 7P6 907 273 L HW: 5Q0 907 273
Component: RDKBERU30 H04 0003
Serial number: 30000000014326 Dataset Number: 7P6096V____ 0029
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30_005.rod
VCID: 45D08E53A525E1522CD-8010
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4H0 907 383 M HW: 4H0 907 383 K
Component: Anhaenger H14 0137
Revision: 7C001001 Serial number: 0366815620 Dataset Number: 7P0124v____ 0008
Coding: 0200000200000000
ASAM Dataset: EV_TrailFunctGener2Hella 001005
ROD: EV_TrailFunctGener2Hella_VW52.rod
VCID: 372CF49BEFC983C2AE1-8062
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H08000 Serial number: 525 PA8JA31852
Coding: 0130001
VCID: 372CF49BE34983C2AE1-8062
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 108500272 Dataset Number: 7p0771v____ 0012
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202142
ROD: EV_HeckkTouar.rod
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0306
Revision: -------- Serial number: 0000146178850
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 41
Mileage: 291663 km
Time Indication: 0
Date: 2024.12.23
Time: 08:59:03
End----------(Elapsed Time: 02:18, VBatt start/end: 14.5V/14.7V)-----------[Code]
