Hello,
The question, then background... at slow parking lot speed (<10 mph) what are the ramifications of suddenly throwing a V6 into Park to emergency stop the vehicle. I know its not good, but I figure the electronics of the system likely used the braking system to assist with this rather abrupt maneuver so it couldnt be as bad as a friend throwing a 1960's Baraccuda into Reverse at Freeway speed :|
Why did I use Park?... Stupid situation - leaving a wedding event where I had changed shoes in the car, I had inadvertently left a shoe in the pedal well. While I was able to start the car (having to depress brake), and safely backed out of the parking spot, I suddenly discovered the brake was not responsive (the shoe got caught) and in fact began impacting the acceleration pedal. Not knowing all this at the time and needing to stop very soon to avoid any impacts with cars or people, I did the next thing.
Of choices - turning the Car Off (which may be bad on an electronically controlled car but I have done that on a runaway Firebird whose throttle cable got stuck); throwing into Park (which I did) or Neutral (which may have been better if I could brake); or using the parking brake (which may have been the best of three choices, but not considered on the quick think). What would have been the best choice in hindsight?
Anyway, I have noticed no problems with the vehicle. It runs as good as before - which is very impressive I might add. The car has 3000 miles. But what, if anything should I look for or have a dealer look at during upcoming service? Would the car actually use the brakes to help assist?
As an added note - of all the cars I have driven, I have to say the area behind the pedals of the Touareg are cavernous. I could store luggage back there. Big surprise.
