1 - 20 of 87 Posts
2016 VW Touareg Executive
Starting a new thread specifically for understanding the capabilities of DLA on the 7P.
Much to my frustration, my 2016 Executive is loaded up with all the safety features with radar and fancy camera and adaptive lights, yet it's unable to automatically regulate High and Low beam.
If you read VW's press releases from back in 2011, the fancy adaptive lights had the ability to control the HID beam through active shutters -- the same ones that are engaged when I manually enable high beam. In the US, thanks to our antiquated lighting regulations, it would seem that any of the clever engineering is disabled.
My aim with this thread is to gather information on both US and non-US models, and determine whether my US version has the hardware to enable this functionality -- assuming we can figure out the coding for enablement. I'm wondering if we still have to change out a headlight module for this.
I've dug around in the modules, and while 85 seems to have some features for active shutters, I'm unable to crack the code on how mod 09 would actually enable it, assuming that's required. I'd appreciate anyone sharing a few pages from a euro owner's manual, any scan information, pictures of dashboard lights, mod 09 details, etc. I have shared my auto scan and label information with RossTech already.
From what I can understand, the Touareg uses a different module strategy than vehicles like the Golf, or even some of its Audi cousins. As always, I appreciate all your time and information for even reading this or contributing.
Learner
lets see where we can get with this....this should help ....
now I think we need the label file for module 09
Learner
And if you haven't already, checkout this page for how we can contribute info to RossTech
Control Module Maps - Ross-Tech Wiki
I definitely think it's Module 09 that is our nemesis right now.
good points you make.
meanwhile did some research and it appears that you are on the money, the Touareg xenons are all permanently masked - from 2011 with xenons that is.
and it is this roller type mask that controls DLA and also the high and low beam! all this sounds very cool but we still need to figure out the combination across the front camera, image processing(8E), camera control unit and xenon headlight.
could be all too easy with a vcds scan from a Touareg that already has DLA working.
the camera sees upto 800meters for incoming cars and 400m for cars travelling in the same direction and activates function when
- headlight switch is in auto
- gets dark signal
- speed above 60km
- DLA activated via nav screen
should be easy to atleast get the option in nav for DLA, will start with that
- gets dark signal
- speed above 60km
I have DLA option, and have it activated, but I haven't noticed any of this function mentioned. I however use the headlight switch manually. Does it need to be in auto for sure? I will have to try that. Car is a Canadian 2013 TDI. It should be mostly the same as the USA model I believe. They definitely don't dim at all for oncoming traffic.
Learner
Hi NSTouaregTDI, thanks for your note. When you say you have the DLA option and its activated, how do you qualify this and know for sure you have this option?
Yes, switch must be in Auto position and other parameters must be met as mentioned above. Do you have vcds, are you able to share your scan?
It is an option in the stereo that you can enable and disable. The other parameters are met, except I don't really use the auto position. I will have to try that. I've tested it out on twinned highways, and regular two lane roads, well over the required speed, and no dimming. Perhaps that's just due to my switch position though. I am away from my car until October 12. It's home in Halifax, NS, and I'm all the way on the other side of the country in Vancouver, BC. I will certainly be investigating when I get home. I have posted auto scans on here in other threads before. Does a general auto scan provide the information you need, or is it some sort of other scan?
Here's the autoscan from shortly after when I bought the car:
Tuesday,15,August,2017,15:17:50:52362
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
Data version: 20170721 DS276.2
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 42 46 52 53 55 56 5F 62 65 69
6C 6D 72
VIN: WVGDP9BPXDD011514 Mileage: 84991km-52810miles
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
Address 01: Engine (J623-CNRA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 K HW: 7P0 907 401 K
Component: 3.0TDI EDC17 H20 0004
Revision: 56H20---
Coding: 292A4012233600050000
Shop #: WSC 28831 001 1048576
ASAM Dataset: EV_ECM30TDI0117P0907401K 001005
ROD: EV_ECM30TDI0117P0907401K.rod
VCID: 37282350FFC14C1FAA0-8062
1 Fault Found:
5604 - Park/Neutral Switch Input Circuit
P0850 00 [032] - Open or Short to Plus
Intermittent - Not Confirmed - Tested Since Memory Clear
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels 0C8-927-750.clb
Part No SW: 0C8 927 750 AK HW: 0C8 927 750 AK
Component: AL1000 AISIN 002 2269
Serial number:
Coding: 001368
ASAM Dataset: EV_TCMAL991031 002114
ROD: EV_TCMAL991031_002.rod
VCID: 75B4E958A54DFE0F78C-8020
No fault code found.
Address 03: ABS Brakes (J104) Labels 7P0-907-379.clb
Part No SW: 7P0 907 379 P HW: 7P0 907 379 A
Component: MK25A H36 0446
Revision: -------- Serial number: 404130010EC815
Coding: 5B7613C349252554DAF9C89492D6A4407300
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 008001
ROD: EV_ESPMK25A00800.rod
VCID: 4ACE6AA49C33C1F7C5E-801E
Part No SW: 4H0 907 064 CK HW: 4H0 907 064 CK
Component: BCM2 2.0 H33 0433
Revision: 00002001
Coding: 09860010000000000000
VCID: 74B2D45CAEB7E7074F2-8020
Subsystem 1 - Part No SW: 7P6 959 754 AD HW: 7P6 959 754 AD
Component: FBSTOUAREGIDG H04 0051
Serial number: 0813000004697015
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H40 0046
Serial number: 2312000285046001
Address 08: Auto HVAC (J255) Labels 7P6-907-040.clb
Part No SW: 7P6 907 040 BK HW: 7P6 907 040 BK
Component: Klima 2 Zonen H20 1305
Coding: B606000880
VCID: 7EA6F674907BBD57296-802A
1 Fault Found:
15360256 - Component Protection
U1101 00 [008] - Active
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 3
Reset counter: 32
Mileage: 81102 km
Date: 2017.07.16
Time: 16:06:06
Voltage terminal 30-Data: 11.2 V
Terminal 15 status: Terminal 15 on
Component protection-Data: 31
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0130
Revision: 15012002 Serial number: 00000001513079
Coding: 26001012D73C5D010020180300005D0C431C66080201024100 0000020000
VCID: 6C82CC3CF6873FC7972-8038
Component: WWS 130203 031 0021
Serial number: 90243400130207210859
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 20061450
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Serial number: 00000000000102130730
Address 15: Airbags (J234) Labels 7P0-959-655.clb
Part No SW: 7P0 959 655 C HW: 7P0 959 655 C
Component: VW10Airbag02B H05 0025
Revision: -------- Serial number: 003L0006KWYU
Coding: 000000000000000000000000000000003242
ASAM Dataset: EV_AirbaVW10BPAVW526 001001
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 41DC4D88A10502AF144-8014
Seat occupied recognition:
Serial number: 5850000R127300A90A
Serial number: 3575LRB405L1S1NI601F
Crash sensor for side airbag: front passenger side:
Serial number: 3585LRB405L1S1NIAH4/
Crash sensor for side airbag: rear: driver side:
Serial number: 3515RRB40044UP6A8187
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525RRB40044UP6A598D
Serial number: 3555NRB401A50D60PPB7
Serial number: 3565NRB400450D62SGUG
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 F HW: 7P6 953 507 L
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815MBB0009U
Coding: 000015
VCID: 36362E54F84BB517B16-8062
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0233099
Address 17: Instruments (J285) Labels 7P6-920-xxx-17.clb
Part No SW: 7P6 920 881 G HW: 7P6 920 881 G
Component: Kombi H13 0318
Revision: 13240077 Serial number: 658080213592032
Coding: 0B2733002B000008020004
ASAM Dataset: EV_KombiUDSRBVW526 001017
ROD: EV_KombiUDSRBVW526_VW52.rod
VCID: 40DA488CAA0F0BA71BA-8014
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 7P6 907 530 F HW: 7P6 907 530 F
Component: GW-CAN-L-MOST H11 6028
Revision: -------- Serial number: 00000000820742
Coding: 000103AD00
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
VCID: 3B203F60C3E9687F4E8-806E
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000004191040415
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4H0 959 793 N HW: 4H0 959 793 F
Component: TSG FA H07 0166
Revision: -------- Serial number: 0000052520697
Coding: 011D07200000453005080000
VCID: 44D2449CBE9717873F2-8010
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0300333828
Coding: 0186123A28B9101480A0062021000000000000000000000000 0000000000
Subsystem 1 - Part No: 1K0 951 605 C
Subsystem 2 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.055 H01 0008
Serial number: WOO2014179+
Coding: 191100
Subsystem 3 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.055 H01 0008
Serial number: WOO2013509.
Coding: 191100
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0166
Revision: -------- Serial number: 0000052231288
VCID: 3B203F60C369687F4E8-806E
Address 53: Parking Brake (J540-) Labels 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C1320300002
Coding: 01040200
ROD: EV_ParkbA7.rod
VCID: 36362E54F8CBB517B16-8062
Slave 3:
3 Faults Found:
0051 - No Calibration
B2010 F0 [008] - Deviation From Expected Range
Freeze Frame:
Fault Frequency: 1
Reset counter: 76
Mileage: 75640 km
Date: 2017.03.16
Time: 13:27:17
Voltage: 11.6 V
0052 - Parking Brake Motor; Right
C10BD 07 [008] - Mechanical Failure
Freeze Frame:
Fault Frequency: 1
Reset counter: 48
Mileage: 75640 km
Date: 2017.03.16
Time: 13:27:18
Voltage: 11.0 V
0040 - Motor for Electronic Parking Brake
C10E3 29 [008] - Signal Implausible
Freeze Frame:
Fault Frequency: 1
Reset counter: 48
Mileage: 75640 km
Date: 2017.03.16
Time: 16:47:00
Voltage: 12.0 V
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Revision: -------- Serial number: --------------
Coding: 010A00010F000400
ASAM Dataset: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFS_VW52.rod
VCID: 7CA2FC7C8667AF47072-8028
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0003
Coding: 130000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0003
Coding: 130000
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 082 D HW: 4G0 035 082
Component: Radio U SIRIU H60 0112
Revision: AB001007 Serial number: 156BU0D7650612
Coding: 020007020100000001
VCID: 211CED0841C522AF744-8074
Part No SW: 7P6 035 664 C HW: 7P6 035 664
Component: H-BN-NA H45 0544
Revision: -------- Serial number: 445BV0D7543531
Coding: 010200050040E1EE01002B0C00000003F0000101
VCID: 382A206CF25F4367A3A-806C
Subsystem 1 - Part No: 8R0 060 884 AM
Component: NAR 2012 0605
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H26 0045
Serial number: VWZ8Z9M7900HVG
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Subsystem 4 - Part No: 8R0 060 961
Component: CD-Database 1886
Address 62: Door, Rear Left (J38 Labels: None
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0167
Revision: -------- Serial number: 0000052239113
Coding: 011C07200000253005080000
VCID: 3A2E3A64CC53517755E-806E
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000095762
ASAM Dataset: EV_RDKBERU25 003006
ROD: EV_RDKBERU25_VW52.rod
VCID: 3FD84B70D7F1745F620-806A
Address 69: Trailer (J345) Labels: None
Part No SW: 7P0 907 383 F HW: 7P0 907 383 B
Component: Anhaenger H11 0110
Revision: 5A001001 Serial number: 00000192526742
Coding: 020D000000000000
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H06000 Serial number: 525 PA8J311437
Coding: 0110001
VCID: 37282350F3414C1FAA0-8062
Address 6D: Trunk Elect. (----) Labels 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 025300179
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202142
ROD: EV_HeckkTouar.rod
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H09 0167
Revision: -------- Serial number: 0000052535909
Learner
Ok thanks, will search for your posts and see if i can find your scan meanwhile.
A general scan of all modules would be fine.
Try it on Auto, at night, above 60km and see what it does. Do let us know.
Learner
Just saw you scan, thanks again!
From what i gather, and i am not 100% on this yet, you donot have DLA.
The option in the nav isnt enough to actually have DLA, many of these 'options' can be turned on without even having the actual feature.
For DLA to work it needs image processing camera in the windscreen and the 8E module which you dont seem to have in your scan
Discussion Starter · #12 ·
Yeah, as an FYI, here is my scan, showing the image processing camera installed:
VIN: WVGEF9BP2GD012278 Mileage: 27655km-17184miles
08-Auto HVAC -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
47-Sound System -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
8E-Image Processing -- Status: OK 0000
Discussion Starter · #13 ·
Also, I'm curious about these part numbers (screenshot attached), as there are two for the "range control"
I have the first one, yet there is one with a Z suffix that I can't seem to find much info on.
It is not an inexpensive module, and I believe it is behind the glove box on left hand drive vehicles.
Learner
J745, seems to be the same
Learner
from ssp 470, following are the functions of the front camera, interestingly the camera is used for ACC to decipher between cars, trucks ahead....
Learner
I wonder why the option would be enabled from VW in the menu, if my car doesn't even have the right hardware for the feature. Weird..
fair question. did you buy your Touareg brand new? is the hidden menu enabled?
Even buying a brand new vehicle from a dealer doesnt ensure that all the setups are correct. When I bought my last Touareg - straight off the showroom the TPMS wasnt enabled and available!
Do VW have the right processes to ensure all setups are correct for each car before delivery..hmm..
In the Nav green screen menu one can enable features so they appear in the standard menu but only if you have the modules in your car then they can be configured and switched on via vcds with correct coding.
I didn't buy it new, but I don't believe the previous owner did any modifications. It was one of many vehicles he owned, had it all dealer serviced, and left it completely stock. I haven't checked to see if the green menu is enabled yet or not. Something I should enable myself if it isn't. You'd think VW would do a better job of making sure only options that appear in the menu actually exist on the car, but apparently not.
Discussion Starter · #19 ·
Does anyone know if vehicle scans from Touaregs with the DLA would be sufficient for us to figure out what coding is needed? I tend to think it won't be enough, but I don't know how to contribute to the module 09 "label" effort?
Learner
I am certain it would. We just need to find one....the label file was there in previous version of vcds, 14 or 15 i think, dont know why they removed it
Reactions: skelly14
1 - 20 of 87 Posts
