1 - 10 of 10 Posts
Hello, I have a loud whirring noise coming from below the centre console.
It's the exact same sound as described in this youtube video.
He says its the bearing and not the rubber mount and he had to replace the entire drive shaft.
Can someone please expand on this issue for me? It is absolutely necessary to replace the entire part? Seems expensive!
2011 VR6 FSI LUX
It does sound like a bad bearing noise.
If it were the rubber mount you would most likely hear a knocking noise from under the center armrest. You can check the bearing mount by crawling underneath and seeing if there is excessive play in it.
The prop / drive shaft centre bearing is a very well known failure point on Generation 1 cars, the T1 and the T2, where there are several different fixes ranging from $0 (The Jimi Fix) to $2,000 (new shaft)!
However there have been very few reported failures on the Generation 2 cars, the T3 and T4, but I don't recall anyone coming up up with any of the Gen 1 quick (and cheap) fixes.
'14 TDI Execline
Here's one of the hits from the search I suggested running above
Discussion Starter · #8 ·
Forgot to mention 2011 VR6
Hey everyone, so I did more research and I am positive the bearing has gone, and not the rubber bushing. As I went under and inspected the bushing and it seemed 100%, zero play.
So what to do... I have narrowed it down to 2 options.
- Option 1: Replace entire drive shaft with new or used ($1200-$800 not including install)
- Option 2: Remove driveshaft and take to local shop to be rebuilt ($350 not including install)
From this very informative video I watched, I will not be attempting to replace the bearing myself, it involves a lot of components that are press fit, which means special tools to take it apart and put back.
(For the uninformed on what the job actually entails to replace this centre support brearing, this is a great video)
I'm somewhat handy, so I think I could potentially remove the drive shaft myself or with a buddy.
I'm not sure the extent to how long I can run the car with the bearing shot like this. I WFH often and weekly driving is usually around 50km maybe. I will go back under this weekend and spray the area with WD-40 and maybe put a little wheel bearing grease and see what happens.
If anyone has any tips on removeing a drive shaft your self I'd be open to the insight.
If its the centre bearing, then best option Ive found is to take car to a driveshaft specialist to repair. They’ll remove the shaft, cut off and replace the bearing, re balance it and refit all in a few hours for around $450. Easy and you’ll still retain your quality OEM shaft.
1 - 10 of 10 Posts
