1 - 3 of 3 Posts
Hi everyone, having an issue with the drivers seat in my 2013 Touareg. The seat back is wobbling/rocking which seems quite unusual. Only slightly but it is noticeable and becoming pretty annoying as you can imagine! Has anyone else had this issue ? Any ideas on what could be causing it? Cheers in advance!
Didn't you have your battery replaced recently? And were the seat rail bolts renewed and tightened properly? Even if you had no battery replacement, check the bolts anyway.
Sounds like the rail bolts were not fully torqued or were stripped/cross-threaded.
1 - 3 of 3 Posts
