Dreaded NoX Sensor Issue
19K views 72 replies 9 participants last post by  annamarks
What’s up Club T Reg? I am wondering if someone can help me with this new Nox sensor 2 bank 1 code that i’m getting after some recent exhaust work. (see below)
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 7P1 907 401 C HW: 7P0 907 401 K
Component: 3.0TDI FSA H21 0010
Revision: 56H21--- CVN: AF4B74E538D3FF8238D3FF820E1FC39E
Coding: 292A4012237600050000
Shop #: WSC 95884 999 00000
ASAM Dataset: EV_ECM30TDI0117P1907401C 001011
ROD: EV_ECM30TDI0117P1907401C.rod
VCID: 303916C2BAAD461B5B2-8065
VINID: 9E65D48094A001650000510614AD580033
1 Fault Found:
9561 - NOx Sensor 2 Bank 1
P229E 00 [236] - Electrical Malfunction
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 19
Mileage: 132352 km
Date: 2022.12.30
Time: 19:11:53
Engine RPM: 1687.00 /min
Normed load value: 80.4 %
Vehicle speed: 103 km/h
Coolant temperature: 94 ∞C
Intake air temperature: 5 ∞C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.840 V
Unlearning counter according OBD: 40
NOx sensor 2: NOx concentration: 150 ppm
Com r Lam Lin Rec Cat2 Ds: 0.9430
NOx sensor 2: feed voltage: 14240 mV
Target value of heating temperature of NOx sensor 2-Bits 0-7: 1
Com st N Ox Vld Cat2 Ds-Bits 0-7: 0
Exh st Lam Stat No Cat2 Ds-Bits 0-7: 1
Exhaust gas temperature sensor 4: 356.8 ∞C
Readiness: 1 1 0 0 0
#61 ·
so you don’t think a wire melted for nox sensor and at same time melted the seat angle adjuster wire (maybe if it’s located in the same harnness). I don’t know. Also if it’s just the fuse can you point me in the right direction to find that? I have never saw where the fuses are located on my T reg TBH.
#62 ·
You have no idea what you're looking or for, and @Dannyboy485 is confusing you by showing examples from him working on big transport rigs. What he has shown you doesn't exist on your vehicle.
You asked if the seat wire and NOx sensor wire were in the same harness. They are not.
You asked if one can short the other or if it's conincidental. A couple of us told you that they are unrelated.
About knowing where the fuses are... Look at your owner's manual. It should tell you where fuses can be found.
#63 ·
Thank-you to everyone that has given me input on this! much appreciated! I have an update from the Dealership. They are ordering new nox sensor and also replacing fuel injector leaking issue with a head gasket replacement on the bank 1 side only...( i think). They are doing it under warranty. Is there anything else I should be asking them or anything else you might that of that could also be the issue?
#66 ·
I'd start thinking about selling this lemon. If you're already needing head gaskets and injector seals at that kind of mileage, I'd take that as all kinds of red flags.
If you were more up to speed on your mech/tech/diy stuff, you might be ok, but based on what's happening now, you might regret owning this once the warranty runs out.
I don't even understand why you needed a new DPF already.
#67 ·
Well i have 2.5 years left of extended warranty. I will try and resolve all issues i can. I’ve maintained very well otherwise. All these issues started immediately after the emissions software was put onto it. Something probably went wrong first time they did it.I’m the only person who has ever driven it, besides mechanic.
#69 ·
I'm just keeping it real.... I mean, these clowns messed up swapping over a NOx sensor between the two cats... And now they are cracking your engine open... Which of these repairs do you think has a greater potential for catastrophic results if butchered?
How long are they gonna take for the repairs this time around?
