1 - 6 of 6 Posts
I replaced my 2004 Toureg V8 with a 2013 TDI lux and I need snow tires.
I have a set of original Touareg V8 18 inch rims from the 2004. Do these fit on the 2013 T3 TDI lux (which came with 19 inch from factory)?
Is the bolt pattern and the offset the same?
Yes. [So do 17s!].
With the exception of the R5 Engine Touareg (different lug pattern) and the "It has to clear your brake calipers" reminder... you can put any Touareg wheel on any year Touareg.
And 17s don't fit the V10 either!
And neither the R5 nor the V8Tdi went to the US anyway!!
Blah. Humbug. Take off the brake caliper and rotor, then the 17s will fit on both those vehicles. ;-)
tldr: The limiting factor of which Touareg wheels will fit is normally the brake system. "It has to clear your brake calipers."
1 - 6 of 6 Posts
