Calling on the brain trust to help me once again. This vehicle loves to test you.
After solving my battery drain stemming from my rear passenger door black button shorting out (I unpinned the wire) it seems a new annoyance has sprung up as my battery is dying again.
This time with the front passenger door antenna. Interesting how these fault codes appear in module 5, but it is actually module 46 where you can view live data for the components.
Strangely, while you can view live data for the little black button, you cannot do the same for the antenna. Can anyone confirm the same observation?
Does anyone know if the antenna can be a cause for battery drain? My Kessy makes clicking noises, so I know it’s likely failing, could it instead just be the kessy module tripping things up, or is my best solution unpinning the antenna wire as well?
It’s a shame because while the black button on that door is inoperable, the keyless entry works flawlessly.
