Hello guys,
I decided to install heating for rear seats without OEM pads, only with OEM buttons.
Suitable model: with 2-zone climatronic (doesn't have rear air conditioning panel)
Use this MOD at your own risk! I am not responsible for any damage that you cause to your car.
!! Installation is completed.
Here is the list of parts:
Heating pads wiring: (my case)
- Console compartment 7P6863092A
- Right heating switch 7P6963106A (white light)
- Left heating switch 7P6963105A (white light)
- 2x connector 4D0971636 (without index) guides are on the edges
- heating pads with 3-level switches (u can buy on Aliexpress as me), it must have 3 level switches - this is important!
- cables to get power from fuse box
- wire for direct and stable power from battery
- ACC+ wire (wire offers power/electricity only when ignition is ON)
- 2 fuse box pins (large)
- spray adhesive for fabrics
Function | Chinese switch (my case) | OEM Switch |
Switch output | Brown | PIN 1 |
LED Stage 1 | White | PIN 2 |
LED Stage 2 | Yellow | PIN 3 |
LED Stage 3 | Blue | PIN 4 |
Light dimming | Red | PIN 5 |
Ground | Black | PIN 6 |
- Red wire (larger) - direct power (+) from battery
- Black wire - negative
- Red wire (thin) - ACC+ power from ignition
- Orange wire - light dimming
