Tools Needed:
19mm socket (lugnut removal)
Needle nose pliars
Hammer
Channel lock pliars
Screwdriver
Steps:
1. Raise vehicle
2. Remove wheel
3. Locate the Cotter pin and just pull straight up using your needle nose pliars
4. Using a screwdriver and a hammer, punch out the retaining pin from the outside in. The pin only goes one way out.
5. Remove the pin and take off the pad retaining spring
6. Unplug the brake pad sensor from the harness
7. Now it's time to push the piston back. With the OEM pads still installed, use the channel lock pliars to retract the pistons.
8. Here are what the pistons look like retracted
9. Install the pads, brake pad sensor, route the sensor into the appropriate slots and plug it in. (I disabled the brake pad sensor so I didn't do this step )
10. Installation is reverse of removal. Remember to install the retaining pin with the "eye" facing up so you can reinstall the Cotter Pin. It is also easier to push the retaining pin while you push down on the brake pad retaining spring.
VERY easy.
Needle nose pliars
Hammer
Channel lock pliars
Screwdriver
Steps:
1. Raise vehicle
2. Remove wheel
VERY easy.
