this is a non mechanic version on how to change the fuel pumps and also insight on some of the fuel systems major components.
DEALER WANTED 2500 TO DO THIS JOB. I SAID F YOU PAY ME
TOOLS NEEDED
HAMMER, FLAT HEAD, SWIVEL ADAPTER FOR BACK SEAT BRACKET BOLTS, 10M TRIPLE SQUARE BIT (I USED A MALE 8MM HEX BIT BUT BE VERY CAREFUL IT CAN STRIP BOLT), 10MM SOCKET, NICE LED HEAD LAMP OR GOOD LIGHTING.
PARTS
2 FUEL PUMPS FOR $168 EACH PASS/DRIVER- ONLINE
1 FUEL FILTER ASSEMBLY $158-ONLINE
TIME
1HR 5MIN. (IN MY DRIVEWAY @NIGHT WHILE RAINING)..I KNOW I NEED AN AWARD OR SOMETHING
step 1. pull tab on rear seats and pop up, then flip forward or towards the front.
step 2. cut carpet, there is a pre cut hole partially present from stock.
step 3. remove 4 10M triple square head bolts on each seat belt bracket(2)
step 4. remove 4 10mm nuts from aluminum lids (2) set lids aside.
step 5. vacuum any dirt and debris around area under lids.
step 6. remove electric plug, and fuel hoses (on both driver and passenger sides) and tuck to the side and out of the way, also keeps rags on deck for gas spillage(use clamp tool to remove fuel line or have strong fingers lol)
step 7. use flat head and hammer to tap brass ring loose. set aside.
step 8. DRIVERS SIDE: pull up fuel filter assembly 3 inches or so and disconnect 2 electrical plugs, let drop in tank, didnt harm anything. this will give you room to pull assembly up more.
step 8A. then remove 2 fuel line from the bottom of the fuel filter assembly. dont worry about mixing up the line because they are two different diameters. leave FF assembly set on top because next step needs to be dont in order to free additional line coming from FFA(fuel filter assembly).
step 9. PASSENGER SIDE: pull up fuel regulator enough to disconnect elec. wires and then remove 2 fuel lines from bottom of regulator. regulator should freely come out, set aside. FUEL TANK RUBBER SEAL(WHICH SEALS FFA/REGULATOR AND TANK) NEEDS TO BE KEPT AS IT CAN BE USED AGAIN.
step 9A. disconnect fuel lines inside of tank, one of which is comes from fuel FFA.
step 10. disconnect fuel lines inside of DRIVERS SIDE TANK, one of which comes from the passenger side fuel pump. FUEL TANK RUBBER SEAL(WHICH SEALS FFA/REGULATOR AND TANK) NEEDS TO BE KEPT AS IT CAN BE USED AGAIN.
step 11. unclip a black hose from top of fuel pump (BOTH DRIVER AND PASS. HAVE THIS HOSE WITH CLIP, WHICH ARE VERY EASY TO UNCLIP.
step 12. man grip the top of pump and turn left 1/4 way til pump releases and remove, BE CAREFUL GAS WILL SPILL FROM PUMPS.
you will use reverse operation to install new pumps. ONLY THING I WILL ADD HERE IS THAT THE RUBBER TANK SEAL NEED TO BE PLACED BEFORE YOU SET FFA/REG. BACK INTO HOLE, AGAIN RUBBER SEAL NEED TO BE SEATED FLUSH AROUND OPENING OF TANK HOLE. THIS CAN BE TRICKY AS YOU HAVE TO HOLD FFA/REG. UP ABOVE TANK HOLE AS YOUR ATTEMPTING TO PLACE TANK SEAL
if you are also installing new FFA then apply as needed. KEEP IN MIND THAT FFA CAN BE OPENED WITH 6 STAR BIT TO CHANGE FILTER INSERT ONLY ($40) VS. ($158 ) FOR NEW FFA FROM EBAY.
** PLEASE NOTE THAT IF YOU DECIDE TO OPEN FFA, THERE IS A RUBBER O RING THAT MUST BE LUBED WITH GAS AND FIT AROUND UPPER PART OF FFA TO PROPERLY PUT BACK TOGETHER. MAKE TRIPLE SURE THAT FFA IS PROPERLY SEALED, ANY LEAKS FROM FFA WILL IN FACT CAUSE ENGINE TO NOT START.
ALSO NOTE THAT I AM NOT RESPONSIBLE IF YOU F THIS UP BECAUSE IT TOOK ME AN HOUR, CONSIDERING I CLEAN CARPETS FOR A LIVING LOL.
TOOLS NEEDED
PARTS
TIME
