The mirror will only dip if the knob is set to the right mirror.
When does the seat move? Mine returns to original position when I turn the car off and get out (if I've adjusted the seat forward / up while the car is running).
I haven't had any issues with the fuel door. I unlock it when I get out to fill it up, I close it when I'm done and it stays latched.
FWIW
Scott
· Premium Member
kompressor kanada said:
is this a feature on all R5 Treg's?
I have a base model V6 and my mirror doesn't dip in reverse.
it never did.
In North America, I believe this is only if you have seats with memory settings. But you should be able to set the mirrors to sync in the MFI. Then you can dip them manually simultaneously with the mirror adjuster when you back up.
